22mm ITR sway and Tiebar?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Liquidgsr »</TD></TR><TR><TD CLASS="quote">whered did you get ur BSQ kit from?</TD></TR></TABLE>
here:
http://www.geocities.com/bretq/mounting_kit.html
here:
i kinda copied the bsq kit for mine. he has dimension for what you need. i ran to home depot got some washers (for spacers) and thin plating for under 5 bux. with a saw and a drill, i was done.
I have the exact same question.
Do you guys think the neuspeed one will fit?
http://www.modacar.com/product...DASTB/
the one for $85
the one for $85
I have a Beaks lower rear tie bar w/ my ITR rear sway and BSQ kit.
Beaks and JIC Magic bar are the only 2 rear lower bars that fit w/ the BSQ/Beaks subframe kit that I know of.
If you want to use Skunk2, Spoon, Neuspeed, DC, or Benen you will have to get the Beaks aftermarket tie bar upgrade kit. It's $20 shipped for the necessary hardware.
http://www.beaksproducts.com/L...t.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sys3rror »</TD></TR><TR><TD CLASS="quote">Beaks and JIC Magic bar are the only 2 rear lower bars that fit w/ the BSQ/Beaks subframe kit that I know of.</TD></TR></TABLE>
There are actually 4 tie bars that I'm aware of that will fit with the ITR rear swaybar and my BSQ kit. Benen, Spoon, JIC and Comptech. The Comptech rear lower tie bar has been discountinued but you may be able to find one still.
i've got a cheap EBAY rear lower tie bar, I'll try to put it on tomorrow to see if it fits for you guys. It was off my stolen 94 SI so hopefully it'll fit on my 94 Teg w/BSQ kit and ITR rear sway. I'll post up pictures.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BSQ »</TD></TR><TR><TD CLASS="quote">
There are actually 4 tie bars that I'm aware of that will fit with the ITR rear swaybar and my BSQ kit. Benen, Spoon, JIC and Comptech. The Comptech rear lower tie bar has been discountinued but you may be able to find one still.</TD></TR></TABLE>
thanks, im gona look for a comptech
I'm running a DC Sports rear lower tie bar with my ITR 23mm sway /BSQ kit and haven't had a problem.
you just need two washers between the tie bar and frame support.
My buddy is running a Ebay DC Sports look alike with his 22mm and BSQ kit, It may be a Arospeed...?...But his bolted on without any additional washers .
The Comptech is the best because of the way it mounts and the fact it spreads its force over 8 dedicated bolts vs 2 load bearing bolts like the others.
The comptech mounts exactly like the ITR bar. you do need a drill, but no big deal.
ThaiPhob
Yeah. If you have a link for the write up that would be great. Thx. Neuspeed is the losest priced one. The computech one is well over $100.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spender1326 »</TD></TR><TR><TD CLASS="quote">ThaiPhob
Yeah. If you have a link for the write up that would be great. Thx. Neuspeed is the losest priced one. The computech one is well over $100. </TD></TR></TABLE>
you ask and you shall recive...
https://honda-tech.com/zerothread?id=606056
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spender1326 »</TD></TR><TR><TD CLASS="quote">EG6SI
PIC's of JIC-Magic installed pls.
this is hayabusa160's ride with the JIC bar (it's the silver one that hangs down the most)
and here is a picture of the Beaks lower tie bar
for all the people who help me when i need it!
