mismatching intake and exhaust cams
Old May 13, 2004 | 01:42 PM
DC2*Integra's Avatar
Default mismatching intake and exhaust cams
im thinking of putting in ctr intake cam and skunk2 exhaust cam. is that going to cause any problems?
Old May 13, 2004 | 01:50 PM
tilt's Avatar
Default Re: mismatching intake and exhaust cams (DC2*Integra)
doubt it
Old May 13, 2004 | 05:59 PM
Default Re: mismatching intake and exhaust cams (tilt)
anyone else?
Old May 13, 2004 | 06:14 PM
here are the specs
ctr intake specs are: 11.5mm, duration 243 @ 1mm
and sk2 stg 1 exhaust are 10.9 mm, duration 249 @ 1mm
am i better off sticking with both ctr intake n exhaust? or will this setup give me better gains?
Old May 13, 2004 | 06:25 PM
NightRiderS2K's Avatar
In-N-Out Burger
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2*Integra &raquo;</TD></TR><TR><TD CLASS="quote">here are the specs
Why would you want to do this? The CTR intake and exhaust gives the best flow, being one of the best OE cams out there. Why mix and match? I might be a lil uneducated but in theory, do you think you will get better gains?
Please enlighten me.
-NRG
Old May 13, 2004 | 06:27 PM
Default Re: mismatching intake and exhaust cams (NightRider-gsR)
i found a good deal here for just the sk2 stg1 exhaust cam. and i also found a good deal for ctr intake cam around my area. so, im trying to figure out if ctr/sk2 setup will be better than the usual ctr exhaust and intake cams because they will both cost the same
Old May 13, 2004 | 07:38 PM
sPaRk'iT's Avatar
i said do it.
Old May 13, 2004 | 07:43 PM
shermanyang's Avatar
Default Re: mismatching intake and exhaust cams (sPaRk'iT)
do it, get on a dyno and check your gains. slap back on the OE CTR cams and hit it up again. then take your pick
bokals
Jul 28, 2010 04:17 PM
Ra GS-R
Aug 10, 2007 03:50 PM
DC2*Integra
May 13, 2004 06:25 PM
DC2*Integra
May 13, 2004 01:26 PM
surferdc2
May 10, 2004 08:26 AM
