Rim rubbing caliper?
Old May 13, 2004 | 11:52 AM
romancenwva's Avatar
Default Rim rubbing caliper?
I have a 92 Honda Civic. We just replaced the brakes all around and now the front drivers side rim is rubbinf against the caliper. There is metal shavings and stuff everywhere. We thought it was from having stripped studs but we replaced all four and it is still doing it. This is the only side doing it. I have called Honda dealerships and asked and one gyu said it was the ball bearings, one guy said check all of the nuts and bolts, etc. Each person has given me different answers. Does anyone know how to solve this problem????? I need asap. If you do know how and would like to email info please email romancenwva@yahoo.com. Thank you in advance.
Old May 13, 2004 | 11:58 AM
Katman's Avatar
Default Re: Rim rubbing caliper? (romancenwva)
what part of your brakes did you replace, specifically?
Old May 13, 2004 | 11:59 AM
I replaced the pads on the front
Old May 13, 2004 | 12:07 PM
I tried checking the bolts and we trpiled checked that the brakes were on right. Any ideas what else could be wrong
Old May 13, 2004 | 12:39 PM
Katman's Avatar
Default Re: (romancenwva)
you sure you bought the correct pads for your car?
Old May 13, 2004 | 03:34 PM
ScottEK's Avatar
Default Re: (Katman)
If you have aftermarket rims without the right offset they will rub the caliper bracket, don't ask how I know.
Patrick18
Feb 26, 2015 10:01 AM
hondafdj444
Feb 21, 2014 05:55 PM
DaiJekBok
Sep 8, 2006 05:25 PM
jagged4698
Sep 4, 2005 09:45 PM
redlineintegra
Sep 7, 2004 09:33 PM
