Koni Yellows Adjustment?
Old May 13, 2004 | 10:34 AM
GreenGSR311's Avatar
Default Koni Yellows Adjustment?
I just put the Koni Yellows on my car with H&R Sport Springs. The Konis are adjustable by turning the **** for soft or firm performance. I believe they are supposed to turn a full 2 turns, but only one of mine does. The other 3 corners turn exactly 1 and 3/4ths of a turn. Is there something that I missed?
Old May 13, 2004 | 10:48 AM
rastropovitch
Guest
Posts: n/a
Default Re: Koni Yellows Adjustment? (GreenGSR311)
1.75 is correct
Old May 13, 2004 | 11:26 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Koni Yellows Adjustment? (MSchu)
yep, if one turns 2 full turns, it might be messed up. 1.75 turns is correct.
Old May 13, 2004 | 11:43 AM
Boofster's Avatar
Default Re: Koni Yellows Adjustment? (PatrickGSR94)
Are you sure? I've had two sets over the last 5 years and all mine turn a little more than 2.
Old May 13, 2004 | 10:00 PM
Anyone else have this problem?
Old May 14, 2004 | 07:02 AM
Community Builder
Default Re: Koni Yellows Adjustment? (Boofster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boofster &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure? I've had two sets over the last 5 years and all mine turn a little more than 2.</TD></TR></TABLE>
100% positive, 1.75 turns full soft to full firm. Mine and my friend's Konis are both like this. I seem to recall the Koni instructions stating this also, but I can't remember for sure.
Old May 14, 2004 | 09:45 AM
WalkmanX's Avatar
my front ones probably is about 2.25 turns from soft to stiff where as my rear ones only require 1.75 turns...I'll double check later tho
Old May 15, 2004 | 05:31 PM
I am going to call Koni on Monday and see what they say.
Old May 15, 2004 | 06:20 PM
AlphaKennyWun's Avatar
2.25 turns here too.
Old May 15, 2004 | 10:18 PM
Community Builder
Default Re: Koni Yellows Adjustment? (Turbo Chris)
Just checked mine, definitely 1.75 turns on all 4 corners. I have the regular off-the-shelf Koni shocks, maybe the SP3 (Neuspeed) versions turn more than 2 turns?
Old May 16, 2004 | 05:15 AM
rottencorpse's Avatar
mine is 1.75
Old Aug 25, 2004 | 08:37 PM
hondandy's Avatar
Default Re: (rottencorpse)
my neupeed yellows(all 4) turn almost 2 turns. But more than 1.75. Maybe 1.9. Sorry now this thread is more confusing
Old Sep 9, 2004 | 09:36 PM
dc2_tuner's Avatar
Default Re: (hondandy)
does it matter if they are yellows or reds???
Old Sep 10, 2004 | 07:46 AM
Community Builder
Default Re: (dc2_tuner)
Koni Sports (yellow) are externally adjustable via a **** placed on top of the shock piston.
Koni Specials (red) are not externally adjustable. You can adjust between 3 different damping settings, but you have to remove the shock, compress the piston all the way down, and then turn the piston to change the setting.
Old Sep 10, 2004 | 10:01 PM
dc2_tuner's Avatar
Default Re: (PatrickGSR94)
SO I GUESS THE YELLOWS ARE BETTER STYLE/QUALITY!
Old Sep 14, 2004 | 06:03 PM
dc2_tuner's Avatar
Old Sep 14, 2004 | 06:36 PM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2_tuner &raquo;</TD></TR><TR><TD CLASS="quote">SO I GUESS THE YELLOWS ARE BETTER STYLE/QUALITY!</TD></TR></TABLE>
Koni Sports are much more versatile than the Specials, and can handle a wider range of spring rates. I'm pretty sure they are not affected by amount of drop, either.
jlh22179tx
Suspension & Brakes
Oct 20, 2006 11:39 AM
MaltBeer
Suspension & Brakes
Jul 23, 2006 08:48 AM
be.twenty
Suspension & Brakes
Aug 2, 2005 10:25 AM
crooked muffler
Jun 29, 2003 09:06 PM
pcorad
Apr 21, 2002 08:48 PM
