how many degrees is one tooth on a b-series cam gear?
Old May 13, 2004 | 10:22 AM
99B16Si's Avatar
Default how many degrees is one tooth on a b-series cam gear?
as it says...and one know for sure? degrees on the cam not the crank
Old May 13, 2004 | 10:59 AM
tgreaves's Avatar
Default Re: how many degrees is one tooth on a b-series cam gear? (99B16Si)
I can tell you how it is on a sohc motor.. The cam degrees would be double that of the crank degrees.. But anyway its about 9 degrees for 1 tooth..
Old May 13, 2004 | 11:32 AM
99B16Si's Avatar
i figured it was somewhere around 10 on a bseries but im not sure
Old May 14, 2004 | 10:12 PM
Top Ramen's Avatar
Default Re: (99B16Si)
A circle has 360 degrees. Count the teeth and divide.
seanewing
Jul 10, 2011 08:53 PM
sleeperb16a
Sep 24, 2007 08:12 AM
Gojira D.O.T
Feb 25, 2006 02:34 AM
donnjuan2point2
Apr 20, 2004 11:20 AM
