need help taking off hose from PCV valve
Its stuck on there pretty tight. Is there some trick to taking it off? should i lube it with something like WD-40 before I attempt to take it off?
you can use silicone spray or WD40 if it's stuck good. any hoses generally I get my trusty 45 degree toothless pliers and give it a light squeeze, spray some soap/water mixture in it, and give it a little twist. pops right off!!
SinsEvil666
Sep 7, 2008 03:14 PM
