Ok, Im done guessing...what springs are they? And a rubbing Q
Old May 13, 2004 | 06:44 AM
pdiggitydogg's Avatar
Default Ok, Im done guessing...what springs are they? And a rubbing Q
I bought these springs a long time ago (so I dont have the box) and theyre supposed to be h&r sport springs....however, from the drop that they give me I really think theyre the race springs instead.
so...what's your opinion?
I installed a 205/45/16 tire set the other day and now I rub like crazy...small bumps, big bumbs, turning....rolling down a flat piece of road...
So, if these are, in fact, race springs...would buying a different set of springs, that are less of a drop, help w/ the rubbing or does everyone w/ a 205/45/16 rub and just deal w/ it?
Old May 13, 2004 | 07:13 AM
bbarbulo's Avatar
I had 205/40/17 for a long time, I never rubbed... your offset is raped. The rims are no good for you. All that rubbage won't go away under full flex anyways, so like an off camber turn that you take too fast will still rub-a-dub-dub even if you have stock springs in there. Looks like a sagged Sport drop. The race drop is hella low. That does not look hella low.
Old May 13, 2004 | 08:15 AM
see I dont know how the offset could be that bad...rota c8s are what...43? That should be alright...shouldnt it?
Im seriously concidering getting rid of these wheels/tires for a 15" set
pm me if anyone has trades available
Old May 13, 2004 | 08:21 AM
ImportHatch's Avatar
Default Re: (pdiggitydogg)
Is it rubbing on your inner fenderwells or the lip of the fender?
Yager-
Old May 13, 2004 | 08:45 AM
both...
Old May 13, 2004 | 08:51 AM
AutoXer's Avatar
The drop looks weird too... the fronts are tucked, and there's wheel gap on the back, or is it just the pick? Could they be installed on the wrong ends of the car?
Old May 13, 2004 | 09:09 AM
nope, thats how it is...well as far as the fronts being 'tucked' if anything is less than 1cm inside the fender.
They are installed right...I did it myself
Old May 13, 2004 | 09:22 AM
BANGBANG's Avatar
Default Re: Ok, Im done guessing...what springs are they? And a rubbing Q (pdiggitydogg)
red x
Old May 13, 2004 | 10:09 AM
dantastic's Avatar
waht color are the springs? if i remember correctly, black springs are sport, race are red
Old May 13, 2004 | 10:11 AM
Navid OG's Avatar
Default Re: (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">waht color are the springs? if i remember correctly, black springs are sport, race are red</TD></TR></TABLE>
u are right... had both sets... RED is RACE and BLACK is SPORTS
Old May 13, 2004 | 10:26 AM
ah alright, that clears it up then
they are black springs
but then it should be a 1.75" drop in the front and I know it is more than that
Old May 13, 2004 | 03:07 PM
up for early evening people
Old May 13, 2004 | 03:24 PM
IntegrAdvan's Avatar
If you bought them used, maybe a coil (or two) has been cut off for more of a drop in the front?
Old May 13, 2004 | 03:53 PM
fishnfst's Avatar
Default Re: (IntegrAdvan)
bingo
Old May 13, 2004 | 04:45 PM
nope I bought them brand spankin new
Old May 13, 2004 | 04:48 PM
GetawayInMoscow's Avatar
Bump because I also want to hear what the 205 45 r16 tire boys are running suspension wise.
Old May 13, 2004 | 06:30 PM
R0ADRAG3's Avatar
either your springs are settled too much for 16's, or you should get coil overs, which would give you new springs anyways. nice ride too
Old May 13, 2004 | 06:57 PM
VtecAdil's Avatar
Default Re: (GetawayinMoscow)
im running 205/45/16 with rota C8's and i rub with tein s-techs, on turns and on big bumps, i need to figure out why its happening and i think its rubbing on both too, someone help please!
Old May 14, 2004 | 06:02 AM
I know this combination shouldnt rub like this
is there anything that I should check, specifically?
Old May 14, 2004 | 07:51 AM
Chickenball's Avatar
I ran H & R Race springs on Tokico illuminas on 2 different sets of 205/40/16's and 1 set of 205/45/16 and I never got any rubbage. The Race springs are yellow are they not? I got the Neuspeed ones now and they are yellow too. I was told that H & R made the springs for Neuspeed. As for the pic. I think you either may have put together the spring and strut together improperly (bump stops)!? Or the springs may be reversed or cut.
Old May 14, 2004 | 07:54 AM
well, I know none of that is the case^
Old May 14, 2004 | 09:19 AM
civicguyex's Avatar
maybe your front struts are busted?
Old May 14, 2004 | 09:28 AM
no theyre fine
and its springs that hold the car up, shocks only dampen...so it sitting there wouldnt make any difference
Old May 14, 2004 | 10:22 AM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
interesting....
Old May 14, 2004 | 05:43 PM
up one more time for the friday night fanatics and some thought-out responses
