Swapping rear drums to rear disc
Old May 13, 2004 | 06:19 AM
Chickenball's Avatar
Default Swapping rear drums to rear disc
Ok folks I have done searches on this topic but there is kind of a twist. Can you just take the drums off by using the 50 Torx bit and put the donor disc and calipers on without the trailing arm? I have run across searches for this but all of them have the switch with the trailing arm. My donor trailing arm has been damaged from an accident. Need some insight on this. Thanks in advance. Trying not to plague HT with irrelevant questions!
Old May 13, 2004 | 08:05 AM
Default Re: Swapping rear drums to rear disc (CBracing)
Anyone?
Old May 13, 2004 | 08:06 AM
IS3Fifty's Avatar
you need that trailing arm. What are you swaping in>> GSR, Si, Type R???
Old May 13, 2004 | 08:09 AM
Default Re: Swapping rear drums to rear disc (TODAeg6)
GSR rear calipers and Rotors to a 93 Civic coupe SI with drums. I also have all the hardware (lines, cables, etc)
Old May 13, 2004 | 08:13 AM
IS3Fifty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBracing &raquo;</TD></TR><TR><TD CLASS="quote">GSR rear calipers and Rotors to a 93 Civic coupe SI with drums. I also have all the hardware (lines, cables, etc)</TD></TR></TABLE>
that's good. No GSR control arms??? 93 Si coupe??? there was no Si coupe for the EH chassis.
Good you have all the necessary line, but you need the control arms it was to be a full swap out.
Old May 13, 2004 | 08:19 AM
nonsense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TODAeg6 &raquo;</TD></TR><TR><TD CLASS="quote">there was no Si coupe for the EH chassis.</TD></TR></TABLE>
there was in canduh . . . it's the same as the US EX. The Canadian SiR is the same as our Si hatch.
Old May 13, 2004 | 08:33 AM
IS3Fifty's Avatar
Default Re: Swapping rear drums to rear disc (nonsense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense &raquo;</TD></TR><TR><TD CLASS="quote">
there was in canduh . . . it's the same as the US EX. The Canadian SiR is the same as our Si hatch. </TD></TR></TABLE>
gotcha
Old May 13, 2004 | 10:25 AM
Sorry Canadian model. So will this work? THis is an EG.
Old May 13, 2004 | 10:37 AM
kommon_sense's Avatar
AFAIK, yes you can. The trailing arms are the same except for what brake is attached to it. I swapped the whole arm when I did mine, but I've read threads where people only swapped the brake assembly.
Old May 13, 2004 | 10:48 AM
h22avid's Avatar
Default Re: Swapping rear drums to rear disc (kommon_sense)
You can do it either way. Either swap the whole trailing arm assembly which is the easiest or just leave your trailing arms in and swap over all the disc components.
Old May 13, 2004 | 10:51 AM
carsaregood's Avatar
agreed, it will work... i'm in the middle of doing it myself on an extra set i have. It looks like you just undo the 4 torx, and the big spindle nut on the back, and put the disk spindles back on. The disk spindles have the appropriate mounting holes for the calipers.
also i think the torx is a T55 size. if you have any luck getting those torx bolts out (without an impact wrench), let me know how!
Old May 13, 2004 | 11:42 AM
h22avid's Avatar
Default Re: Swapping rear drums to rear disc (carsaregood)
use a breaker bar or any pipe slipped over a rachet so you can get some leverage
Old May 13, 2004 | 11:54 AM
Default Re: Swapping rear drums to rear disc (h22avid)
Yeah when I took the Torx nuts off I had a ratchet and I used an old seat post off my bike. Thanks for the help.
Old May 13, 2004 | 01:11 PM
blacksol95's Avatar
I USED THE WHOLE ARMS FOR MY SWAP
Old May 13, 2004 | 02:00 PM
Default Re: Swapping rear drums to rear disc (blacksol95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacksol95 &raquo;</TD></TR><TR><TD CLASS="quote">I USED THE WHOLE ARMS FOR MY SWAP
The question was whether or not I can use the parts off the arms as the trailing arms are BENT! Please read the whole post before you post. And also take your CAPS LOCK OFF! Its annoying!
Old May 13, 2004 | 02:06 PM
Ricey McRicerton's Avatar
The question was whether or not I can use the parts off the arms as the trailing arms are BENT! Please read the whole post before you post. And also take your CAPS LOCK OFF! Its annoying! </TD></TR></TABLE>
Werd.
Old May 13, 2004 | 10:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22avid &raquo;</TD></TR><TR><TD CLASS="quote">use a breaker bar or any pipe slipped over a rachet so you can get some leverage </TD></TR></TABLE>
well i did try using an 18" breaker bar, with the trailing arm wedged up against a table leg, and my friend standing on it. The problem isn't torque, its grip. The torx bit just wants to twist right out of there... i'm probably just retarded but do you guys have any other tips?
Old May 14, 2004 | 04:35 AM
h22avid's Avatar
WERD... READ BEFORE YOU POST AND STOP YELLING
Old May 14, 2004 | 07:45 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carsaregood &raquo;</TD></TR><TR><TD CLASS="quote">
well i did try using an 18" breaker bar, with the trailing arm wedged up against a table leg, and my friend standing on it. The problem isn't torque, its grip. The torx bit just wants to twist right out of there... i'm probably just retarded but do you guys have any other tips? </TD></TR></TABLE>
You must be using the wrong Torx bit. Make sure its a 50. Someone said 55 but I tried and that was just a little too big. Other than that. The mountain bike seat post was a nice leverage tool!
Old May 14, 2004 | 09:16 AM
99_Ek9's Avatar
I swapped the hubs over without using the trailing arms and it worked perfect. It is kinda hard to take the torx bolts out without an impact wrench. I used a bad a#s Snap-on impact...
Old May 14, 2004 | 11:07 AM
rice4life's Avatar
Default Re: Swapping rear drums to rear disc (99_Ek9)
don't forget, you still need the right e-brake cable.
Old May 14, 2004 | 05:22 PM
You must be using the wrong Torx bit. Make sure its a 50. Someone said 55 but I tried and that was just a little too big. Other than that. The mountain bike seat post was a nice leverage tool! </TD></TR></TABLE>
you guys are right, my memory serves me poorly. I went outside and it is a T50. I mixed it up because i bought 2 bits, a T50 and T55, and returned the T55.
Old May 14, 2004 | 05:42 PM
3 G's's Avatar
Are you doing something similar like this thread?
https://honda-tech.com/zerothread?id=426445
I was about to try doing the rear disc that way, but I ended up swapping the arms anyways cause I stripped the torx bit in there for not using an impact driver sooner........oh well, they were on the drums anyways.....
Old May 14, 2004 | 06:13 PM
sceg's Avatar
Default Re: Swapping rear drums to rear disc (3 G's)
thanks for finding that one, i was working on the same thing....
Old May 14, 2004 | 07:26 PM
fishnfst's Avatar
Go and buy a impact driver one of the hand held ones that you put the torx bit into and when you hit the head with a hammer it turns the bit at the same time. I use one to take off front rotors all of the time.
