can't find a spot to put catch can
talk to the forced induction guys.. thats the only reason to have a catchcan anyway is if your running turbo... other than that its just a show piece taking up space and dirt...
if you look @ my engine on the right of the battery on the fire wall is where i put mine,but to do this you need to buy a small battery,lucky enuff i had a jdm type-r battery laying around to do it
,the battery plate needs to be cut if it gets in the way of the can .
p.s. im using the endyne catch can system too....
hope this works
heres mine we made a braket out of aluminum and moved the wire harness so we did not haev to drill new holes
and a catch can does help if you road race (keep your car at high Rpm for extended periods of time) ...if you actually know how a catch can works you would know why this is reasonable ......for those who do not know try a search it has been coverd more times then I can count
oh and one more thing ...the catch can should be mounted higher then the PCV valve's location due to the fact that heat and vapor rise and if it is lower the can will not work to its full potential
is it just me, or do you guys also notice a loss in low end torque when installing a catch can? it seems like my intake pressure has dropped since i installed my can.
