???throttle body and axle questions???
i snapped my TPS sensor off my H22 TB. i took the TB off my old H23 and installed that on there. is this OK? they looked exactly the same so will this work? how do i get the TPS sensor off the TB if i want to?
next question:
can i use my H23 axles on my H22 and do i really have to replace the lock-ring on the passenger side? it looks ok.
next question:
I broke my TPS off my H23 when takin it out and my H22 came alread broken, so i took one off an old '92 accord and it works just fine. The JDM TB comes with just torque bolts holding the TPS in place but the US motors try to screw u over by makin you replace the whole TB so i took a dremel and drilled out the rivets to get my TPS off the accord TB
I also used my H23 axles on my H22 swap. they work fine as well, at 2,500-3,000 there is some clunking on my petals when under accelleration but i dont know if it comes from this. If anybody can give me input on this it would be great. But i am pretty sure the axles are the same and will work fine
good luck man
good luck man
