b18b rod on a gsr crank?
They are not a direct swap.The GSR rods are thinner at the crank end.You would have to narrow the LS rods and use the GSR bearings.The next thing is the LS rods are shorter so the pistons would be way down in the cylinder and would need a custom piston to correct this.
Glenn
Glenn
Mfoehrkolb
Nov 21, 2007 05:37 PM
dem0nk1d
Feb 4, 2007 01:32 PM
