Valve Clearence specs??
I have a 88 CRX Si, d16a6. Previous owner put in a mild street cam from Gude (bullfrog). Couldnt find the valve spec sheet.. any1 have an idea what it is?
BTW I emailed gude, but chances are I will never get a reply. (2nd attempt)
i would go by stock clearances on that cam. sit there with the 10mm and a flathead adjusting each one's distance between the lobe and the lifter. use a feeler guage.
that's how i did my skunks. everything seems fine and i haven't blown my head to **** yet.
oh yeah...when you tighten it to lock it in place it will get more clearance since you draw the valve tighter into the retainer. so it will take a few to get the feel for it.
pegasus_D1^A6
Aug 21, 2006 06:34 PM
TheShocker
Dec 16, 2001 10:01 PM
