will changing 4 lug hubs for 5 lug hubs work>????
Old May 12, 2004 | 02:07 PM
ECKOTYPER's Avatar
Default will changing 4 lug hubs for 5 lug hubs work>????
i wanna do 5 lug conversion to my gsr... found a site brand new the hubs are 145$ each for the rear and 99$ each for the front so thats a total of 500$ roughly for a 5 lug conversion and then have to spend a good 200$ for slotted rotors for 5 lug will this work though???? sounds like a good idea =D but is it doable?
Old May 12, 2004 | 02:12 PM
FFormula1's Avatar
Default Re: will changing 4 lug hubs for 5 lug hubs work>???? (ECKOTYPER)
Plus calipers...
Old May 12, 2004 | 02:13 PM
Dan GSR's Avatar
i know that the fronts will work
but you also need
caliper
brake pads
rotor
extra lug nut
new wheels
new wheel bearings
all that adds up quick
Old May 12, 2004 | 02:18 PM
ECKOTYPER's Avatar
Default Re: will changing 4 lug hubs for 5 lug hubs work>???? (Dan GSR)
are the calipers bigger? i m sorry i searced through 10 pages and didnt find a article on this well i need new rotors for my 4x100 anyways so hehe are the itr calipers bigger? maybe i could trade em at autozone with my gsr cores =D hehehehe
Old May 12, 2004 | 02:33 PM
FFormula1's Avatar
GSR calipers aren't going to clear type R rotors.
Old May 12, 2004 | 02:59 PM
1GreyTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECKOTYPER &raquo;</TD></TR><TR><TD CLASS="quote">i wanna do 5 lug conversion to my gsr... found a site brand new the hubs are 145$ each for the rear and 99$ each for the front so thats a total of 500$ roughly for a 5 lug conversion and then have to spend a good 200$</TD></TR></TABLE>
You're doing the R 5 lug conversion for it's brakes right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECKOTYPER &raquo;</TD></TR><TR><TD CLASS="quote">for slotted rotors for 5 lug will this work though????</TD></TR></TABLE>
Ooop's maybe not, you're a looks guy then? If so I can figure out better ways to spend your money.
Old May 12, 2004 | 03:09 PM
One Bad GeeSeeR's Avatar
you dont need itr calipers if you are using stock gsr rotors. just get the gsr rotors redrilled to 5x114 pcd. that way you can keep stock gsr calipers. but i would do this ie hub exchange only if you are getting itr brakes not just to be five lug. i heard you can do the hub exchange just for the fronts. i dont know if the rear is the same.
Old May 12, 2004 | 03:20 PM
1GreyTeg's Avatar
Default Re: will changing 4 lug hubs for 5 lug hubs work>???? (One Bad GeeSeeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by One Bad GeeSeeR &raquo;</TD></TR><TR><TD CLASS="quote">you dont need itr calipers if you are using stock gsr rotors. just get the gsr rotors redrilled to 5x114 pcd. that way you can keep stock gsr calipers. </TD></TR></TABLE>
Which is entirely a waste of time. And yes I noticed you mentioned something along those lines.
Ahh ohh looks for the summer... Are the 5 lug choices That much better?
Does anyone think that regardless of doing this for the 5 lug look purely, that they will NEED to get their rotors drilled Every Friggen Time they need to get new ones?
Oh, yeah that won't be a big deal, since they won't be going throught rotors very often.
Still a waste of time and money though imo.
Old May 12, 2004 | 03:39 PM
Default Re: will changing 4 lug hubs for 5 lug hubs work>???? (1GreyTeg)
hey 1greyteg do you know if the rears will work? i was going to do this and piece my conversion later. get the hubs and itr rears with either legend fronts or nsx fronts. but dont know if the rear hubs will work.
carlo
Old May 12, 2004 | 03:57 PM
davidnyc's Avatar
Why are you changing for 4 lug to 5 lug ?
Old May 12, 2004 | 04:27 PM
ECKOTYPER's Avatar
Default Re: will changing 4 lug hubs for 5 lug hubs work>???? (davidnyc)
want it for 5 lug hehe i was gonna convert for my integra then put on my ctr shell... id rather buy a 5 lug conversion now hehe so its cool... i figured what ima do =D sell my velox get look alike gabs(rota) in red hehe and 5 lug on the CTR with gunmetal stocks =D thanks anyways guys
Old May 12, 2004 | 08:31 PM
redline32's Avatar
i did 5-lug on a 95 si, fronts and rears work. all you need for the rear is the hub assembly, it bolts right up to the trailing arm.
Old May 12, 2004 | 09:09 PM
redline32's Avatar
Default Re: will changing 4 lug hubs for 5 lug hubs work>???? (redline32)
not aloud to instant yet, i used the type r calipers and rotors
Triker
Apr 10, 2012 12:57 PM
denraweb
Nov 29, 2008 07:01 AM
88 rex
Sep 12, 2006 12:52 PM
ozzyman
Mar 8, 2004 07:58 PM
mstewar
Nov 6, 2003 06:46 AM
