Tokico's acting funny...
weirdest thing, my struts (illumina's) are acting weird at weird times, sometimes vibration, sometimes one will be more stiff than the rest, seems to more of a temperature effected occurance, because the are perfect from 75 deg and up, has anyone ever seen this before? the install is fine and i have tested it over and over on smooth roads. never had a prob like this with my AGX's on my civic
i can tell when i intentionally rune each side of the car over a wheel friendly manhole cover and that corner does NOT compress the way it should, or the way the other three do.
After reassembling my suspension, I noticed that the dampening selector on one of my illumnas is no longer functioning properly... Are there known problems with illumnas like this?
did it just fall out? or does it just spin on the pin? you could try taking the selector out of another shock if you need to change the settings
Catch 22
36
Jan 11, 2003 02:09 PM
