Where do i get power for Fan?
Old May 12, 2004 | 11:29 AM
jackzzz's Avatar
Default Where do i get power for Fan?
88 crx with D16 i think most of the harness has been changed. The fan was hooked up direct from key on. I want to go back and change it to the sender like it should be. Where is the sender ? I looked at the Haynes manual and it looks like the factory one was on the Radiator? Is it the same on a 96 HX what the motor came out of. Or on the 96 was the sender somewhere else
Thanks
Old May 12, 2004 | 11:47 AM
4drEF's Avatar
Keyboard Humorist
Default Re: Where do i get power for Fan? (jackzzz)
There is a thermo switch on the back of the engine near the oil filter. It provides the ground for the fan circuit when it closes. Positive power is switched and fused.
rossyrossb18a
Jan 7, 2013 06:24 AM
must32
Aug 22, 2008 03:28 PM
rockcity
15
May 23, 2008 06:10 PM
baonest1
Feb 19, 2003 02:12 PM
