teeth counting for gears? b series
Old May 12, 2004 | 11:12 AM
integramic's Avatar
Default teeth counting for gears? b series
Can you one tell me how to figure out each tranny gear? Need to know how to count the teeth to find out which gear s they are from. I know which gear each is but not what model each came from.
Old May 12, 2004 | 02:40 PM
Ekasey's Avatar
Default Re: teeth counting for gears? b series (integramic)
mark a spot using a white grease and count all the teeth all the way around then divide the two by each other (Main Shaft versus Counter Shaft).
Example
Mianshaft = 36 teeth
counteshaft = 24 teeth
Gear ratio = 1.5 so for every 1.5 turns of the mainshaft (your engine input) the output shaft (wheels not takign into accoutn the final drive or differential) will turn 1 time
to figure out the final out put divide 1.5 by the final drive ratio
Example
Gear Ratio = 1.5
Final Drive = 4.4
Final gear ratio = .3409
Old May 12, 2004 | 03:58 PM
integramic's Avatar
Wouldn't happen to know how many teeth on each gear for each tranny would you? The reason being I may only have one of the gears.
Old May 12, 2004 | 04:28 PM
Ekasey's Avatar
Default Re: (integramic)
no becaseu all the gear ratios are pre calcualted you could work backwards to find the appropriate amount start by multiplying by the final drive and then by the other gear that you do have and then you should find the corresponding
Old Jun 3, 2004 | 01:49 PM
integramic's Avatar
Default Re: (eLusive ek4)
So if I have a 33 and 26 third gear then I have a (what??) tranny?
33/26=1.27 It says s80. but I know it can be a gsr or an ls.
Old Jun 3, 2004 | 02:04 PM
Ekasey's Avatar
count other gears to determine that
Old Jun 3, 2004 | 02:49 PM
integramic's Avatar
Which would help?
Old Jun 3, 2004 | 02:50 PM
Ekasey's Avatar
whicheverr\ ones are different from a gsr trans to an ls
Old Jun 3, 2004 | 04:08 PM
integramic's Avatar
I thought third was the biggest difference?
Old Jun 3, 2004 | 10:29 PM
Ekasey's Avatar
no clue i just know how to count that ****
Old Jun 3, 2004 | 11:30 PM
2k.civic.si's Avatar
the LS 5th gear should be different....
Old Jun 4, 2004 | 03:22 AM
integramic's Avatar
Default Re: (2k.civic.si)
yeah, That is why I think it was an ls is because I had to change the final and main shaft to get the type r lsd to work.
Darrell Woods
Transmission & Drivetrain
Nov 1, 2015 09:18 PM
wyatt89
Oct 1, 2009 12:41 PM
JV
38
Jan 13, 2009 10:09 PM
Midori Green
Apr 30, 2008 09:11 PM
Jared
Mar 15, 2003 02:18 PM
