Differences in obd1 and obd2 T/B's (GSR)
Old May 12, 2004 | 10:02 AM
Comp97GSR's Avatar
Default Differences in obd1 and obd2 T/B's (GSR)
I was wondering, if a t/b from a 97 GSR could work on a obd1 mani?
The coolant lines on the bottom are completely different. There is a EVAP canister vac. port on the obd1 t/b whereas the obd2 doesn't.
Thank you in advance. (TIA)
Old May 12, 2004 | 11:18 AM
Comp97GSR's Avatar
Default Re: Differences in obd1 and obd2 T/B's (Comp97GSR)
I guess nobody knows??
Old May 13, 2004 | 06:48 AM
CWITR's Avatar
anybody?
Old May 13, 2004 | 08:57 AM
IN VTEC's Avatar
EVAP purge line-in to the solenoid is missing on OBD-2 TB's.
FITV is missing on OBD-2 TB's.
I'm OBD-1 as well. I have both on my desk and I'm gonna probably use the OBD-2 TB for the overbore and bolt that one on. I won't need the FITV, and the EVAP line - I'll just tap into the intake pipe.
Look at the EVAP purge diagrams in the manual. It can explain everything if you look and think about it for a bit.
Old May 16, 2004 | 08:10 AM
CWITR's Avatar
Default Re: Differences in obd1 and obd2 T/B's (IN VTEC)
thanks
91(si)hatchey
Apr 2, 2009 10:45 AM
stsRacer22
Acura NSX
Jun 23, 2005 08:22 PM
bocian
Aug 13, 2002 01:50 PM
matteg02
Apr 18, 2002 12:27 AM
