Used R - expected expenses?
Old May 12, 2004 | 09:13 AM
Nuts's Avatar
Default Used R - expected expenses?
R with 50K miles.
What are some big upcoming spending?
some I could think of:
- Timing belt
- Rotors
- Pads
- all fuild to be replaced
Old May 12, 2004 | 09:14 AM
Larkin W.'s Avatar
Default Re: Used R - expected expenses? (Nuts)
Water pump when the timing belt is done - Shouldn't need this stuff done till 90K-105K miles
Old May 12, 2004 | 09:16 AM
Bbasso's Avatar
wheel alignment ?
Old May 12, 2004 | 09:18 AM
.RJ's Avatar
.RJ
Shouldnt need anything at 50K.
Follow the service manual... will need a bunch of stuff at 60K. Timing belt/water pump at 105K.
Old May 12, 2004 | 09:27 AM
Flux's Avatar
Default Re: Used R - expected expenses? (.RJ)
Do you have any maintenece records for the car?
If I purchased a used car I would immediatly do the following (more for my own peace of mind).
Change oil and filter
Replace spark plugs and possibly wires
New cap and rotor
Flush brake fluid
Valve adjustment
Close inspection of brake system and suspension
Old May 12, 2004 | 09:30 AM
typer_801's Avatar
Default Re: Used R - expected expenses? (Flux)
I wouldn't think you'd need anything beyond what Flux has suggested under the guise of normal maintenance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux &raquo;</TD></TR><TR><TD CLASS="quote">Do you have any maintenece records for the car?
New cap and rotor
Flush brake fluid
Valve adjustment
Close inspection of brake system and suspension</TD></TR></TABLE>
Old May 12, 2004 | 09:39 AM
Mugen Type R's Avatar
change all 4 bearings, the integra weakness
Old May 12, 2004 | 09:41 AM
.RJ's Avatar
.RJ
Default Re: (Type R 98-870)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type R 98-870 &raquo;</TD></TR><TR><TD CLASS="quote">change all 4 bearings, the integra weakness</TD></TR></TABLE>
wtf?
muffler bearings?
Old May 12, 2004 | 09:47 AM
Bbasso's Avatar
Default Re: (.RJ)
Ya also need to change the headlight fluid along with the muffler bearings
Old May 12, 2004 | 09:51 AM
Dave-ROR's Avatar
Rotors and pads really shouldn't be an unexpected expense, and they are cheap anyhow. T belt and W Pump as stated are fine until 90k at least. At 60K I'd suggest the normal stuff and the fuel filter even though it's not required.
Personally, I have over 80k on my car and all I've ever done is fluid changes and valve adjustments.
Old May 12, 2004 | 10:31 AM
Nuts's Avatar
Default Re: (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
wtf?
muffler bearings?</TD></TR></TABLE>
hahaha.... reminds me of the headlights fuild.
Good stuff. =D thanks for the heads up guys!
Old May 18, 2004 | 07:37 AM
change all 4 wheel bearings, why would their be 4 muffler bearings on a car, i hope that was a bad joke...
mine were changed at 65 000 km's and where ready to go, so don't expect to keep yours too long if they havent been changed, acura garantied them for 5 years or 100 000 km's after buying my car cuz they knew about the weakness
Old May 18, 2004 | 07:39 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type R 98-870 &raquo;</TD></TR><TR><TD CLASS="quote">change all 4 wheel bearings</TD></TR></TABLE>
Only if they're bad.
67K on my car, wheel bearings are fine.
Old May 18, 2004 | 08:17 AM
RTW DC2R's Avatar
my wheel bearings could use a change, its in the list of things to do before exbl0. 50K here.
Old May 18, 2004 | 08:19 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Re: (.RJ)
I'd change the T belt and water pump sooner personally. Even though I was running slightly more aggressive cams (Skunk stage I's, stock valvetrain) my jumped timing at 75k and nicked some valves. You'll probably be perfectly fine, but the timing belt is cheap insurance.
My wheel bearings have 93,000mi including TONS of dirt roads and are still fine.
Old May 18, 2004 | 08:24 AM
Integra4lyfe's Avatar
Default Re: (ActiveAero)
&lt;insert random joke about theft here&gt;
Old May 18, 2004 | 08:34 AM
uNF$@#!'s Avatar
Default Re: (RTW DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">my wheel bearings could use a change, its in the list of things to do before exbl0. 50K here.</TD></TR></TABLE>
stop going offroading with the ITR
btw, you change 2 front ones, 2 rear hubs
Old May 18, 2004 | 08:37 AM
RTW DC2R's Avatar
you are the offroad bandit, not me lol
&lt;&lt;&lt; keeps all 4 wheels on the track y0
Old May 18, 2004 | 08:49 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Used R - expected expenses? (Dave-ROR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave-ROR &raquo;</TD></TR><TR><TD CLASS="quote">At 60K I'd suggest the normal stuff and the fuel filter even though it's not required.</TD></TR></TABLE>
It's very strange that the replacement of the fuel filter is not specified by Honda as part of the maintenance schedule. I agree with Dave, do it with the 60K service.
Old May 18, 2004 | 08:57 AM
.RJ's Avatar
.RJ
Default Re: Used R - expected expenses? (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">I agree with Dave, do it with the 60K service.</TD></TR></TABLE>
I will be doing mine yearly from now on. The stuff that fell out of my filter @ 60K =
Old May 18, 2004 | 08:58 AM
vtec.dc2's Avatar
thers no need to replace something thats working.. other than maintanance item.. and fuel filter
Old May 18, 2004 | 09:06 AM
Opie's Avatar
An alarm, kill switch, and garage
Old May 18, 2004 | 11:45 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">you are the offroad bandit, not me lol
&lt;&lt;&lt; keeps all 4 wheels on the track y0</TD></TR></TABLE>
When I take mine off road I mean like this...
Alabama dirt roads + me being bored = R losing any value for potential resale
Old May 18, 2004 | 11:50 AM
JDMITR222's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ActiveAero &raquo;</TD></TR><TR><TD CLASS="quote">
Alabama dirt roads + me being bored = R losing any value for potential resale </TD></TR></TABLE>
YEEE HAWW! dog gone that chit looks like FUN!
Old May 18, 2004 | 12:10 PM
Splat's Avatar
Collector-o-Guns and Drinker
New cap and rotor
Flush brake fluid
Valve adjustment
Maybe trans fluid as well?
