Fields SFC--VTEC unit grounding
Old May 12, 2004 | 07:24 AM
pentaq's Avatar
Default Fields SFC--VTEC unit grounding
Hi,
I don't have a harness for this unit, so I must wire it myself. I found a nice write-up about wiring particular sensors etc, so that's not a problem. But SFC must be grounded somehow. Could anyone explain how should I do that?
TIA
pentaq
Old May 12, 2004 | 08:22 AM
92siracer's Avatar
Default Re: Fields SFC--VTEC unit grounding (pentaq)
i grounded mines and my friends to the ground on the ecu.....where the screw that bolts the ecu to the car.
Old May 12, 2004 | 02:14 PM
pentaq's Avatar
Default Re: Fields SFC--VTEC unit grounding (92siracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92siracer &raquo;</TD></TR><TR><TD CLASS="quote">i grounded mines and my friends to the ground on the ecu.....where the screw that bolts the ecu to the car.</TD></TR></TABLE>
...and which pin in the rear plug did you connect to?
Old May 12, 2004 | 10:00 PM
mugenracer's Avatar
I had one in my last teg and just followed the instructions on temple of vtec and spliced into the ECus ground wire, worked fine for a year then i pulled it out when i sold the car.
Old May 13, 2004 | 12:18 AM
pentaq's Avatar
Default Re: (mugenracer)
I still don't know to which pin in the plug I should connect the ground
But thank for your replies.
Old May 13, 2004 | 09:20 PM
mugenracer's Avatar
OBD1 or 2?
Old May 14, 2004 | 01:40 AM
pentaq's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenracer &raquo;</TD></TR><TR><TD CLASS="quote">OBD1 or 2?</TD></TR></TABLE>
OBD1 Prelude 94 VTEC
Old May 14, 2004 | 09:18 AM
92siracer's Avatar
oh duuh!! u need the pinout on the fields cuz u aint got the harness ??? my bad! let me check it out for u and look on my boiz setup.
Old May 14, 2004 | 04:00 PM
pentaq's Avatar
Cool, Can't wait
Old May 16, 2004 | 01:14 PM
pentaq's Avatar
...still waiting...
Old May 17, 2004 | 08:29 AM
pentaq's Avatar
ttt
Old May 17, 2004 | 12:08 PM
hondaguyexsi's Avatar
remember a ground is a ground i know a few people who groung to the block
Old May 17, 2004 | 12:10 PM
wickedEFguy's Avatar
Default Re: Fields SFC--VTEC unit grounding (hondaguyexsi)
best ground is either on the chais or engine block but again a ground is a ground
Old May 17, 2004 | 01:14 PM
pentaq's Avatar
Default Re: Fields SFC--VTEC unit grounding (wickedEFguy)
But VAFC is supposed to be grounded to the same ground as ECU, that's why I'm confused. What is more it must be grounded with two wires and one of them must be closer ECU than another one. Damn, I'm lost.
Old May 17, 2004 | 01:51 PM
well the ECU is ground on the engine where the thermostat is, it connects to the bottle neck part of it. the other ground I'd say would be chasis
eg6madness
Nov 17, 2007 04:46 PM
RCautoworks
Mar 2, 2006 11:37 AM
Ekay Jay
Sep 7, 2005 02:20 PM
xci_ed6
Apr 12, 2005 05:15 PM
CivicSiRracer69
Oct 31, 2004 11:17 AM
