3rd gear trouble
I just put a new clutch & flywheel in my car (2000 SH) . Before that when i would shiff into 3rd at high rpms it would grind a bit &only some times.
So when i install the new clutch & flywheel & i put good tranny oil in i though that that might help. But now it's worst
What could it be ??
What could it be ??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redmethods »</TD></TR><TR><TD CLASS="quote">I just put a new clutch & flywheel in my car (2000 SH) . Before that when i would shiff into 3rd at high rpms it would grind a bit &only some times.
What could it be ??</TD></TR></TABLE>
what kind of fluid did you put in?
grinding gears can be masked for a little while by good MTF, honda MTF is great stuff, and GM syncro mesh and redline MTF are even better. but if you have a 3rd gear grinding problem and ONLY 3rd then most likely you syncro is on its way out.
spoonlongblock
Honda Civic (2006 - 2015)
10
Nov 9, 2006 08:03 PM
CivicSiRX
Sep 23, 2005 08:42 PM
