speed limiter bypass???
hi, ive got a 92 accord with a jdm h22a in it with a p13 jdm ecu... and it running pritty good after the self install, however, i'm still limited in the speed department to 115.... id like to ditch that cause i'm getting that in 4th @ 6000 grand... does anyone know any lil tricks to get rid of the govoner? thanks a ton!!
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx »</TD></TR><TR><TD CLASS="quote">send me the ecu, i can chip it with a spoon ver 1 prog, it will remove the limiter, and gain a few hp as well.</TD></TR></TABLE> yeah sure! chips are crap! dont do it!!
I know if you get the feilds Vtec contorller you can disable to speed govenor, and BTW it is at 118MPH for a JDM P13. Everyone is going to tell you to get hondata because it's the best... maybe you should.
thanks for the help ...everyone. i probably will go hondata ... cause im gona have my custom turbo set up on in a month or so.. i was just wondring if anyone knew how to get rid of that pos limiter a cheap and easy way.. thanks again!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spanishgt99 »</TD></TR><TR><TD CLASS="quote"> yeah sure! chips are crap! dont do it!!</TD></TR></TABLE>
oh really?? so how do u explain the gain of on avg 3-5hp on the dyno that I come up with after I put in the spoon chip on a few of the h22as i have tuned? And i suppose that you have studied the timing maps and compared them to a stock chip an saw that the timing is a bit more advanced up top on the spoon chip, but still came to the conclusion that it is "crap"? I suppose your an expert at this since you speak so confidently, can you please explain to me how the chip is your so called "crap".
The only crap I see is the wad of **** you pulled out of your *** to back up ur statements, so shut the **** up dipshit.
JinDIESEL
Aug 11, 2004 10:48 AM
