ENGINE RUNS IF U HIT GAS RIGHT AFTER START, YOU CAN REDLINE IT , THEN U LET IT GO OT IDLE THEN U HIT
SWAPPED A D16Z6 INTO MY 89HATCH SI AND IT DOES THAT EVERYTHINGS RAN RIGHT ITS CONNECTED ITS NOT THROWIN ANY CODES OTHER THAN MY O2 SENSOR, TAHTS IT AND I DONT KNO WHAT TO DO.. IT CAN REDLINE AFTER START THEN U LET IT GO BACK TO IDLE THEN U HIT GAS AND IT WONT GO PAST 2 GRAND , IT ALMOST SOUNDS LIKE A REV LIMITER, BUT I DONT THINK IT IS I HAVE NO CLUE PLEASE HELLLLLLP
check the actual ecu for codes.. maybe the CEL itself is burnt out..
btw... i guess you swapped to obd1 wiring?
uhm... for some reason Im thinkin that obd1 doesnt have the little light on the actual ECU like obd0.. but if it does just check the light. it will flash out the codes.
msinsky14
20
Mar 21, 2010 08:02 PM
kaddi88
Jul 30, 2008 11:19 AM
