Water on floor
Old May 11, 2004 | 04:00 PM
Josh Carr's Avatar
Default Water on floor
I have the problem of water present on the passanger and driver side floor. Does anyone have a copy of TSB 92-050 that could be emailed or maybe a place that the details are posted?
TIA
Josh
Old May 11, 2004 | 04:35 PM
toyzbus's Avatar
Have you been using your a/c? It sounds like the evaporator drain came undone and it is draining to the floor instead of through a hose to the exterior of the car
Old May 11, 2004 | 04:43 PM
Ricey McRicerton's Avatar
Default Re: (toyzbus)
Could also be the heater core.
Old May 11, 2004 | 05:05 PM
HS2G's Avatar
Default Re: Water on floor (Josh Carr)
yes it is probably the AC hose that got dissconnected. Just pull open the carpet and reconnect it to the exit port.
Old May 11, 2004 | 05:06 PM
Swift's Avatar
yea if it smells sweet then it is most likely the heater core. But it realy sounds like the drain for the ac, like was already stated. Sometimes junk gets in the little tray and it gets clogged so it overflows on the floor, but sometimes over zealous passengers can knock the drain out of place.
Old May 12, 2004 | 07:58 AM
Josh Carr's Avatar
Thanks for all the help, but I had already checked the drain hose for the A/C (which hasn't been used in about a year), and BIG difference between water and coolant. If anyone DOES have a copy of the TSB, could you contact me? Thanks!
Josh
Old May 12, 2004 | 08:10 AM
bbarbulo's Avatar
the drain from the cowl is clogged, causing water to collect and drain in throught he fan opening and onto your floor. seen it before.
DACteg
Jul 27, 2010 11:04 AM
darkestfenix
Jun 24, 2010 09:36 PM
No-Gi
Oct 3, 2009 06:30 AM
Understeer
Jul 23, 2003 02:53 PM
accord-euro-r
May 1, 2002 06:40 AM
