How to wire JDM HID headlights?
I looked at the FAQ but I didnt find a answer; only a foglight wiring diagram.
I just got the entire JDM DC2 front end with HID and I need to know how to wire up the headlights and everything.
Thanks
Thanks
Very Emergency!!
i don't know the thread, but i will explain how to wire up the lights. i have the non-DID headlights, so you will have one extra wire, that is your HID light wire. there should be a brown plug on each light. the green wire is for the city lights, the blue is for the fog lights, and the pink is for the high beam. and of course the grayish wire is the ground. the easiest way is to connect each wire to the brown plug individualy with female crimp conections. i wired up my headlights (minus foglights) in about an hour. on the non-HID the low beam bulb is used. you most likely will have to cut the bulb off and use the power wire and connect that to the HID wire, i think. good luck. oh yeah, you will need a foglight switch and harness for the foglights. do a search for jdm foglight wiring and it should come up.
thanks alot man, ill try that out whenever i have time to get the radiator support put on haha, i just got the front end today
https://honda-tech.com/zerothread?id=105247
https://honda-tech.com/zerothread?id=59167
search is your friend
well to be honest i did and looked at all 15+ links.... and both of those are for the fog lights.... thanks though i never use this board so i dont really know my way around--
thank you so much-- this post needs to be put in the archives that is the best instalation article ive ever seen-- thanks alot man
solsi2000
Mar 15, 2009 03:19 PM
