Idle goes to low
Old May 11, 2004 | 01:51 PM
abeaujuin's Avatar
Default Idle goes to low
When I step on the gas and then let it go with the AC on, as I let off the idle drops below 1000 for a second then comes back to normal.
Can someone help me out with this problem? My other accord doesn't do this.
Modified by abeaujuin at 11:07 PM 5/11/2004
Old May 11, 2004 | 06:17 PM
hybridcd5's Avatar
Default Re: Idle goes to low (abeaujuin)
that is normal
Old May 11, 2004 | 07:14 PM
Riceburner247's Avatar
Default Re: Idle goes to low (hybridcd5)
Mine does that.
Old May 11, 2004 | 07:59 PM
Nathan007's Avatar
your idle normally should be at about 600-750 rpm.. and when u put on the ac, or drain alot of juice..it will go down for a lil bit and then get back alright
Old May 12, 2004 | 09:13 AM
jfastman's Avatar
Remove the air intake hose from the throttle body. Hold the throttle valve wide open and take a look inside. If you see alot black carbon deposits, that may be the reason for the low idle issues. The idle air control valve (IACV) may be "coked up" with carbon deposits. Valvoline makes a nice kit for intake system cleaning. It's called "Syn-power trio".
The ECM receives a signal from the A/C system to idle up the engine when the compressor is activated which is where the IACV comes in. If it's "coked" up with deposits, it's operation may be sluggish.
Dionili Securio
Aug 27, 2018 04:55 PM
da9crxsi
Jun 4, 2012 09:52 AM
2low93
Feb 17, 2012 04:13 AM
LOL@hondas
Aug 13, 2010 11:21 AM
nekoabandoned
11
Jul 2, 2008 11:59 AM
