snaped a bolt help!
thie is a link to a pic Im trying to get it on hear but imagestation is having problems or I am.
http://www.imagestation.com/my...-796f
what can I do? I didn't start the car but I need to know how to fix It I can't fiend any diagrams in chiltons.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by playAho »</TD></TR><TR><TD CLASS="quote">cool where do I get a new one? probobly from honda. so can I drive the car?</TD></TR></TABLE>
If you absolutely have to. I'd make sure to check for leaks/lost oil very often though.
Wow, how did you do that Adam? Oh, that's right...you were checking your spark plugs right?
Looks like you can remove the valve cover, and use a vise grip to twist/remove the stud. You can get the bolt/stud at a honda dealership. Normally what I do is go to http://www.hondaautomotiveparts.com and look at the diagrams they have.
Look at illustration 12 on the diagram. This appears to be the stud that you need replaced:
http://www.hondaautomotivepart...EC%29
Good luck Adam.
Good luck Adam.
ya it came of really tight then I when to re tighten the lower nut and it came of I didn't turn it very far. ow well what can you do. thanks for the diagram im headed to Honda!
I will get those pics for you while im out to.
Those break easy. I drove without one for about two weeks before I finally got around to putting a new one in. Shouldn't hurt anything, but then again, thats not how its supposed to be so fix it.
diddy where did you get your new one from? I didn't torque it down I was turning it on and then it just came of. I tightened them a lot tighter on my old b16 I just think it was this ones time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedsol »</TD></TR><TR><TD CLASS="quote">Wow, how did you do that Adam? Oh, that's right...you were checking your spark plugs right?
Good luck Adam.
Maybe i dont know anything but why would you take that off to check the spark plugs? anyway get it fixed soon. we got races onthe 21st and you need to go!
Good luck Adam.
</TD></TR></TABLE>Maybe i dont know anything but why would you take that off to check the spark plugs? anyway get it fixed soon. we got races onthe 21st and you need to go!
Man if wont be that hard to get out at all. no need for vise grips. Just unbolt of the rest of thevalve cover bolts. Then pull the valve cover off, you will then notice that the stud bolts in with a 12mm socket. You will still have a use a lonlg 12mm socket to get it out tho. Then go purchase a new one at Honda, will probbably cost you like 2.50 for it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">I snapped a valve cover bolt in my head too.
These work fantastic. I was very suprised by how good they are; I didn't expect them to work at all when I bought them. It lloks like he can just get on there with some grips when he pulls the cover off though, since it snapped right at the head of the bolt.
</TD></TR></TABLE>These work fantastic. I was very suprised by how good they are; I didn't expect them to work at all when I bought them. It lloks like he can just get on there with some grips when he pulls the cover off though, since it snapped right at the head of the bolt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlh81 »</TD></TR><TR><TD CLASS="quote">Just take the valve cover off and unsrew it with a 14mm deep socket.
Yes its that easy
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX_AutoXer »</TD></TR><TR><TD CLASS="quote">
These work fantastic. I was very suprised by how good they are; I didn't expect them to work at all when I bought them. It lloks like he can just get on there with some grips when he pulls the cover off though, since it snapped right at the head of the bolt.</TD></TR></TABLE>
NO its not a 14mm, like i said before the one you snaped off was 12mm ,. Also dont go rushing to the store to purchase one of these easy out kits. Your not going to need one for this problem.
Yes its that easy
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX_AutoXer »</TD></TR><TR><TD CLASS="quote">These work fantastic. I was very suprised by how good they are; I didn't expect them to work at all when I bought them. It lloks like he can just get on there with some grips when he pulls the cover off though, since it snapped right at the head of the bolt.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boo bees »</TD></TR><TR><TD CLASS="quote">NO its not a 14mm, like i said before the one you snaped off was 12mm ,. Also dont go rushing to the store to purchase one of these easy out kits. Your not going to need one for this problem. </TD></TR></TABLE>
First of all if you going to talk **** then know your ****
first of all im not trying to talk **** , just trying to give the right imformation. Now he did not give the imformation on what head that was, But from the pic i can tell its eather a vtec or ls head,. If it is a Ls head then i could be wrong with saying that it is 12mm socket not sure what size the ls head uses. But if its a vtec head i know for a fact that it is a 12 mm deep socket. The pic that you posted has the wrong imformation. The only part inside of a B series Vtec head that uses a 14mm socket are the head studs, and that would be a 14mm 6 point.
</TD></TR></TABLE>first of all im not trying to talk **** , just trying to give the right imformation. Now he did not give the imformation on what head that was, But from the pic i can tell its eather a vtec or ls head,. If it is a Ls head then i could be wrong with saying that it is 12mm socket not sure what size the ls head uses. But if its a vtec head i know for a fact that it is a 12 mm deep socket. The pic that you posted has the wrong imformation. The only part inside of a B series Vtec head that uses a 14mm socket are the head studs, and that would be a 14mm 6 point.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deluzional »</TD></TR><TR><TD CLASS="quote">remove your valve cover, and get some vice grips on there, then you should be able to get it out and replace it</TD></TR></TABLE>
