GSR dash
Old May 11, 2004 | 11:54 AM
JDM_ek9's Avatar
Default GSR dash
Will it fit into an EF????
if not what needs to be done to fit???
how about wiring?
Old May 11, 2004 | 12:10 PM
kshymkiw83's Avatar
Default Re: GSR dash (JDM_ek9)
yes it will fit
yes you will have to make it fit
good luck
honestly i have seen a DC2 dash on here, actually a few days ago i believe. He said there was alot of cutting involved to get the dash to look "normal" and he hadn't started on the wiring yet.
You will need a Helms manual for a Civic (88-91 of course) and you will also need one for the GSR you are using, then just match and plug it in. Of course you won't be using the airbags so you could cut those out completely
Old May 11, 2004 | 12:34 PM
Swift's Avatar
This should be it
https://honda-tech.com/zerothread?id=852199
Old May 11, 2004 | 12:42 PM
96-EJ6 B18C's Avatar
Default Re: GSR dash (Swift)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Swift &raquo;</TD></TR><TR><TD CLASS="quote">This should be it
https://honda-tech.com/zerothread?id=852199</TD></TR></TABLE>
Wow, that is pretty crazy! Looks like a TON of work
DarkLP
Acura TSX
Aug 8, 2013 11:29 PM
DAJay93
Dec 2, 2007 09:18 AM
scrooge
Jul 7, 2007 07:03 PM
Jschnatter
16
Sep 17, 2006 12:22 AM
EG-6Ghost
13
Jun 12, 2004 05:35 PM
