h22 transmission
Old May 11, 2004 | 09:14 AM
petahh's Avatar
Default h22 transmission
I have an automatic 95 prelude. is it at all possible to just keep the engine and change out the transmission? or would it be easier to just go out and buy a 5speed h22?
Old May 11, 2004 | 09:33 AM
AndyD's Avatar
Default Re: h22 transmission (petahh)
Changing over to a 5spd is a somewhat tedious task. You will need to locate all the necessary swap parts. I don't think it is as hard of a swap if you pull out the motor, however, I can't speak from experience.
I believe that the hardest parts to find are the 5spd brake and clutch pedals, the clutch reservoir, the tubes from the clutch reservoir to the clutch slave cylinder, and one other item. I can't remember what it is called. I think it is the clutch dampener, but I am not sure.
I think the easiest route would be to find a 90-97 Accord/92-96 Prelude that is totalled and take all the parts needed from it.
Hope this helps
Old May 11, 2004 | 01:06 PM
Old_Nocturnal's Avatar
Default Re: h22 transmission (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">Changing over to a 5spd is a somewhat tedious task. You will need to locate all the necessary swap parts. I don't think it is as hard of a swap if you pull out the motor, however, I can't speak from experience.
Hope this helps</TD></TR></TABLE>
You will also need a new dash cluster, shifter mount, and shifter linkage and cables... But, on a good note, you can keep your ECU... You will need to clip a jumper to disable the lockup solenoid... See pgmfi.org for the jumper location
morales232002
Nov 19, 2006 12:02 PM
zexifiedlude
Feb 1, 2006 08:55 AM
7808
Aug 2, 2005 11:39 PM
SleeprCivic
Apr 26, 2004 02:40 PM
