Misfiring D16
Old May 11, 2004 | 07:27 AM
AutoXer's Avatar
Default Misfiring D16
Hey everyone. This weekend, I took my car to the wash and sprayed the engine. Get on the road to drive it, and it's misfiring. The first thing I think of is the distributer cap, because I used an aftermarket when I did my maintenance. Sure eough it was (water all over the inside), so I got an OEM one from the dealer.
My question is, for the 2 - 5 miles I drove it to the dealer while misfiring (it through a CEL as well) could this have caused any damage to my engine? Everything runs fine now, like it never happened.
Also, on a side note, the tech at honda said to touch the + and - terminals together to reset the ecu to clear the code, and it worked.
Cliff: Driving while misfiring cause damage?
Old May 11, 2004 | 09:17 AM
AutoXer's Avatar
Default Re: Misfiring D16 (EX_AutoXer)
Bump...
Nobody knows if this can cause damage?
Old May 11, 2004 | 09:50 AM
DATZ WEAKSAUCE's Avatar
just a wild guess maybe check your plug wire order maybe u have the plugs on the wrong cylinder
Old May 11, 2004 | 09:58 AM
nub's Avatar
nub
Default Re: Misfiring D16 (sj ninjaturtles)
you should be fine, a missfire from wet ignition parts wont cause damage
Old May 11, 2004 | 10:18 AM
AutoXer's Avatar
Default Re: Misfiring D16 (nub)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nub &raquo;</TD></TR><TR><TD CLASS="quote">you should be fine, a missfire from wet ignition parts wont cause damage</TD></TR></TABLE>
Cool.. that's what I thought, but I wanted to make sure. Thanks so much!
Old May 11, 2004 | 11:54 AM
civicminded92's Avatar
A miss fire like you described would not cause any problems with the engine - basically what it is doing is that spark is not getting to the plug, or not all the time. So, you'd have a cylinder running really rich. Rich could shorten the life of your cat, but not for 2-5 miles.
accordf22vtec
Apr 16, 2020 09:30 PM
adueisaac
Honda Civic (2006 - 2015)
Oct 30, 2012 07:51 AM
HoUTX98GSR
Aug 30, 2007 01:34 PM
krispyaccord
Mar 8, 2007 10:08 PM
