jdm h22 timing specs
Old May 11, 2004 | 12:26 AM
E dwinbon G's Avatar
Default jdm h22 timing specs
ive done a search but couldnt find anything on the timing specs for an obd1 jdm h22. the motor needs the timing corrected since it is back firing right now, so any help at all would be greatly appreciated... thanks
Old May 11, 2004 | 01:31 AM
jmcclell's Avatar
Default Re: jdm h22 timing specs (E dwinbon G)
Base timing should be set to 15 Deg BTDC at 750 RPM.
(Remember to put a loop wire across the service check connector if you are running a stock Honda ECU)
Old May 11, 2004 | 07:23 AM
Rtype16's Avatar
Default Re: jdm h22 timing specs (jmcclell)
Timing being off wouldn't really do that unless it is really off. Make sure your plug wires are on the distributor in the right order.
Old May 11, 2004 | 10:37 AM
Default Re: jdm h22 timing specs (Rtype16)
would having a p28 make any difference as to if it was running the p13?
Old May 12, 2004 | 11:26 AM
bump
somboa
Feb 19, 2013 07:33 PM
95EG2
Jun 3, 2011 11:25 AM
darockstar
May 26, 2006 12:07 PM
darockstar
Mar 25, 2006 12:35 AM
JDM H22
Dec 5, 2004 08:15 AM
