how low before camber kit?
Old May 11, 2004 | 12:02 AM
revenge's Avatar
Default how low before camber kit?
im gettin a "drop kit" for my 5th gen hatch.... some unknown brand springs and blistein shocks.... its gonna be about 2.5" drop... is that too much to not have a camber-corection kit, or is it do-able without one?
ps...... runnin on gsr 16 spoke rims (15x6) if that makes a dif
Old May 11, 2004 | 12:08 AM
djbutler007's Avatar
Default Re: how low before camber kit? (revenge)
it would be better to get a camber kit
Old May 11, 2004 | 03:29 AM
Xsi's Avatar
Xsi
Definately do-able without one, just get an alignment
92b16vx's Avatar
Yea, just take it to a shop an make sure toe is adjusted right, you'll be good.
Old May 11, 2004 | 06:08 PM
revenge's Avatar
right on....... thanks guys
(plus im gettin all the parts for 250 so i couldnt not do it)
Old May 12, 2004 | 04:24 PM
camelian's Avatar
Default Re: (revenge)
hmm, i'm dropped on neuspeed sport springs (1.75 front/1.50 rear) and i have pretty bad camber. ~1.4 deg in the front and ~2.0 degrees off in the rear. Looking at the front tires, the camber wear is showing a bit. I'd get a camber kit for the front. Rear = washers
Old May 14, 2004 | 07:07 PM
daver's Avatar
Default Re: (camelian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by camelian &raquo;</TD></TR><TR><TD CLASS="quote">hmm, i'm dropped on neuspeed sport springs (1.75 front/1.50 rear) and i have pretty bad camber. ~1.4 deg in the front and ~2.0 degrees off in the rear. Looking at the front tires, the camber wear is showing a bit. I'd get a camber kit for the front. Rear = washers</TD></TR></TABLE>
did you get an alignment after the drop, before the wear?
Old May 14, 2004 | 07:21 PM
slammed00si's Avatar
Default Re: (daver)
just get your toe set right and you should be fine.
Old May 14, 2004 | 07:23 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: (slammed00si)
get it aligned... you'll be fine.
JTaudio0212
Honda Civic (2006 - 2015)
18
Oct 25, 2007 04:58 PM
Doom325
Jan 30, 2005 09:00 AM
lazyxazianxboi
Nov 1, 2004 08:32 AM
SiRocket02
14
Jan 11, 2004 09:24 PM
EriK20
Aug 21, 2003 05:47 PM
