good rods for allmotor setup
Old May 10, 2004 | 10:48 PM
thad
Guest
Posts: n/a
Default good rods for allmotor setup
i'm running eagles now, but for it seems like overkill, since i'm not likely to bend or break a rod, short of hydrolocking, i was thinking of using stock ITR or GSR next, worth it to shot peen? Or is there a rod that favors light weight over bulk and strength?
Old May 10, 2004 | 11:18 PM
b16vtecsol's Avatar
Default Re: good rods for allmotor setup (thad)
dpr
Old May 10, 2004 | 11:30 PM
TECH43 RACING INC.'s Avatar
Default Re: good rods for allmotor setup (b16vtecsol)
dpr's are just "probe" rods, basically the same as eagle. forged in china, machined here. same ****. since you've got the eagles, i'd suggest just running them, why spend money to go to a weaker stock rod.
Old May 11, 2004 | 12:05 AM
All-MotorCRX's Avatar
Default Re: good rods for allmotor setup (TECH43 RACING INC.)
tech sup son
Old May 11, 2004 | 12:19 AM
All Toda Dc2
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TECH43 RACING INC. &raquo;</TD></TR><TR><TD CLASS="quote">dpr's are just "probe" rods, basically the same as eagle. forged in china, machined here. same ****. since you've got the eagles, i'd suggest just running them, why spend money to go to a weaker stock rod.</TD></TR></TABLE>
basically the same?
Probe is lighter than stock.
Eagles are heavier than stock.... what makes them the same?
Probe, Manley, IB rods, Cunninghams.
Old May 11, 2004 | 12:28 AM
Default Re: good rods for allmotor setup (All Toda Dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by All Toda Dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
basically the same?
Probe, Manley, IB rods, Cunninghams. </TD></TR></TABLE>
probe's are lighter than eagle, stock, whatever. we're talking a few grams, and with the way guys beat on there street engines these days, over revving etc, they could use the extra strength.
i know probes are a little lighter and not as beefy as eagles. weaker? I dont know. doubtful. my point was that both are probably made in the same forging factory in china....same as peak performance....scat....cat....etc.
are they strong? yeah.
are they cheap? yeah.
will they break? not easier than any other forged rod, which is not easy.
they are not as nice and pretty as cunningham, carillo, crower, manley etc. but the 3x price difference doesnt get you 3x the performance.
oh yeah..and IB rods..reboxed china stuff too.
Old May 18, 2004 | 02:27 PM
SoCaLNaTIvE's Avatar
word to your mom!
Old May 18, 2004 | 04:04 PM
justBLZE's Avatar
Chopper 2 Hopper
Word cuz.
Old May 18, 2004 | 08:38 PM
Professor X's Avatar
I too am interested because I am building an N/A LS/Vtec and I want to get some pretty good rods. Any information is greatly appreciated. Thanks!
Old May 20, 2004 | 10:26 AM
thad
Guest
Posts: n/a
i would stick with the eagles, but it's just a big hassle when using oem pistons, are any of those rods bushed for pressed pins?
Old May 20, 2004 | 10:45 AM
GSRswapandslow.
Guest
Posts: n/a
if you are using oem pistons...then just get some shotpeened GSR rods they're the same damn thing as the ITR rods
but yeah, all of the h-beam rods i know of (Carrillio, Eagle, Crower, Scat..etc..etc...) are all the same rods, but finished in house slightly diffferent. just go with what's the cheapest, which i think is scat right now.
Old May 20, 2004 | 04:08 PM
Rocket's Avatar
Default Re: (GSRswapandslow.)
Make sure the rod bolts are ARP2000 or better. I know of instances where lesser bolts even the bigger 3/8" bolts took a dump and ruined a motor.
Old May 20, 2004 | 05:59 PM
GSRswapandslow.
Guest
Posts: n/a
yeah, good bolts are pretty much necessary on any mild/wild build up....n/a is really stressful, so don't skimp in that area
Old May 22, 2004 | 10:13 PM
rodimus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRswapandslow. &raquo;</TD></TR><TR><TD CLASS="quote">if you are using oem pistons...then just get some shotpeened GSR rods they're the same damn thing as the ITR rods
but yeah, all of the h-beam rods i know of (Carrillio, Eagle, Crower, Scat..etc..etc...) are all the same rods, but finished in house slightly diffferent. just go with what's the cheapest, which i think is scat right now.</TD></TR></TABLE>
a lot of people confirmed that the R rods were lighter and stronger than gsr's?
Old May 22, 2004 | 10:33 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (Rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">Make sure the rod bolts are ARP2000 or better. I know of instances where lesser bolts even the bigger 3/8" bolts took a dump and ruined a motor.</TD></TR></TABLE>
[cough] eagles [/cough]
ya if you already have them , no sence in NOT using them.
Old May 24, 2004 | 10:43 AM
Rocket's Avatar
Default Re: (Hella_JDM)
Just as important as part selection is proper assembly of the short block.
Don't just torque and go. You'll want to check how freely the cranks spins and your oil clearances otherwise you'll have failure that can break any rod.
Old May 24, 2004 | 10:52 AM
Sinbro2's Avatar
Default Re: good rods for allmotor setup (SoCaLNaTIvE)
Cunningham
Old May 24, 2004 | 04:43 PM
NSTY Z33's Avatar
I'm going with eagles for my N/A build.. Please change your avatar pic, that is just scary.
DA_JDM
Feb 14, 2007 06:04 AM
nickgmiller04
May 10, 2004 05:48 PM
Mr HYDE
59
Mar 18, 2004 09:35 AM
Dammit_Dan_954
Nov 30, 2003 11:18 AM
toooslow
Oct 9, 2003 04:16 PM
