2000 RPM Buzz
My 1996 Accord emits loud buzz around 2000 RPM. I checked for loose heat shields everything is ok. Any idea or fix? Please help
May 20 After all day I got my Accord to stop making that annoying BUZZ. Here is what I did to fix the problem : I took apart a and b pipe cleaned and lubricaded the connecting joints , then I drilled 4 holes through the side of bottom , and top Cat - converter shields added 4 heavy duty fasteners. Thanks to the forum members hints my problem is finally fixed.
Modified by kuba35 at 3:51 AM 5/21/2004
I had the same prob. and it was the bracket that holds your B-pipe on to the back of the block...I had bottomed out and the bracket broke and just vibrated on the block...
It's worth taking a look under there cuz it's pretty easy to see if it's broken.
What is this buzz kit you speak of? I too have that 2000RPM buzz....been doing it for several months and is annoying as all get out.
Sounds like it's up front more in the dash....but I can't isolate it either. I do know that some noises throw themselves......so was really wondering more about this buzz kit??
frequency of the engine @ 2000rpm is whats causeing the object to start to shake (just like an opera singer shatters glass when they sing the correct pitch (frequency) with enough volume)
my friends old turbo back exhaust used to set off his radar detector and car alarms, using the same princeple
AdamBl
Apr 27, 2011 07:41 PM
xtal
Jul 22, 2005 11:38 PM
Lowes2win
Jul 7, 2004 03:25 PM
