Help:Takes awhile for engine to heat up!
Old May 10, 2004 | 07:54 PM
miksew's Avatar
Default Help:Takes awhile for engine to heat up!
-upper coolant hose is hot
-lower coolant hose is cool
-integra dual core radiator on b16
-if i put heat on full blast the engine temp drops
-car takes at least 15 min to reach operating temperature
Anyone know whats up?
Old May 10, 2004 | 07:55 PM
Kamin's Avatar
Default Re: Help:Takes awhile for engine to heat up! (miksew)
yea...thats normal at idle.
Old May 10, 2004 | 08:01 PM
miksew's Avatar
Default Re: Help:Takes awhile for engine to heat up! (Kamin)
is it normal to take so long to heat up? in winter my car wouldn't even reach operating temperature with the heat on,is the integra radiator THAT effecient?
Old May 10, 2004 | 08:09 PM
NiceDc2r's Avatar
do you have a thermostat???
Old May 10, 2004 | 08:10 PM
JeffS's Avatar
Check your thermostat... that's the only thing that could be causing slow warmup.
Old May 10, 2004 | 08:15 PM
CoolKat's Avatar
I just had a similar problem, I replaced the thermostat with a new one from Honda and flushed the coolant.
It fixed the problem, so try a new thermostat and bleed it or flush it with new coolant.
dbailey
11
Jan 30, 2020 04:27 AM
WaryDriver
26
Jan 8, 2017 09:54 PM
dlstech
16
Dec 12, 2012 03:04 AM
4doorpowa
Jan 24, 2011 12:50 PM
ef yu
Oct 22, 2010 12:45 AM
