gas pedal/idle problems
Old May 10, 2004 | 05:22 PM
92siracer's Avatar
Default gas pedal/idle problems
when i take off slowly at a light or get ready to take off my idle doesnt go back down when i let off the gas. but it does it 2 out of 5 times.....is my throttle body gettin sticky or whatever? or is it something to do with my throttle cable...i used a gsr throttle cable.thanks
Old May 10, 2004 | 05:28 PM
92civeg's Avatar
Default Re: gas pedal/idle problems (92siracer)
probably just a sticky tb...try cleaning it and go from there
Old May 10, 2004 | 06:10 PM
Jimmy's Avatar
Global Moderator
Brake cleaner works well for this.
Old May 10, 2004 | 06:11 PM
92siracer's Avatar
Default Re: (Jimmy)
thanks....ill give it a try in the morning.
Old May 10, 2004 | 06:19 PM
2lua's Avatar
Default Re: (92siracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">Brake cleaner works well for this.
bad idea...
use throttle body cleaner, cause brake cleaner will desolve the coating inside the throttle body.
Singlecam4dr
Apr 9, 2010 01:42 PM
sevenfc
Mar 27, 2009 05:58 PM
itsJDMyo
May 30, 2004 04:05 AM
Jdmbsixteen
17
Feb 18, 2004 07:54 PM
