Knowing oxygen sensor is Bad
Old May 10, 2004 | 03:08 PM
DropSquadCivic's Avatar
Default Knowing oxygen sensor is Bad
Usually if your oxygen sensor is bad you will thorow a code for it right? Well the only code i am throwing is for my EGR. My car is running really rich. So rich that sometimes when i first start driving it sounds i like my rev limiter is at 3,000 rpms at mid throttle.It kills so much performance from my engine. I want to make sure its my oxygen sensor thats wrong before i go and spend a hundred bucks on an oxygen sensor. But from what i have read so far that about the only to find out if you aren't throwing a code. If someone could hook me up with some answers that would be greatly appreciated.
Old May 10, 2004 | 04:01 PM
RZProStreet's Avatar
Default Re: Knowing oxygen sensor is Bad (DropSquadCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DropSquadCivic &raquo;</TD></TR><TR><TD CLASS="quote">Usually if your oxygen sensor is bad you will thorow a code for it right? </TD></TR></TABLE>
Not necessarily an O2 sensor can become "lazy" which means it is still functioning without a check engine light, but reacting very slowly to air/fuel changes.
What is your fuel pressure at? and what ECU and injectors are you using?
Old May 10, 2004 | 06:01 PM
spaceman's Avatar
theres a way to test the o2 sensor with a voltmeter or something like that..
Old May 11, 2004 | 10:51 AM
Default Re: Knowing oxygen sensor is Bad (RZProStreet)
I think i'm running on 42psi and i have my stock p13 ECU, with stock injectors.
Old May 11, 2004 | 05:46 PM
RedZone's Avatar
Does your map sensor have the o-ring still. I know that if the o-ring is missing it will cause the map to read the wrong vacuum and create a rich environment and will cause the problem you are describing.......
Old May 13, 2004 | 08:57 PM
Default Re: Knowing oxygen sensor is Bad (RedZone)
My map sensor is mounted on the firewall, and there's a male end on it and it connects to my vaccum line. I know what you are talking about though because my map sensor messed up, what's happening with my car now is a lighter version of that. Maybe driving my car with the map sensor messed up for a while might have messed the oxygen sensor.
Old May 17, 2004 | 04:52 PM
bump
Old May 17, 2004 | 05:10 PM
Sliced Beard's Avatar
it happened to me once
i replaced my O2 sensor and my woes went away
Old May 17, 2004 | 07:25 PM
Proper's Avatar
Default Re: Knowing oxygen sensor is Bad (dirtyd463)
To check your o2 sensor's reaction time you would need an osciliscope. I think a good sensor reacts in about 2 miliseconds(could be wrong). So there is no way you could check it with a voltmeter.
Good Luck
-Proper
dbailey
21
Nov 9, 2007 07:08 AM
HCRX311
Jun 7, 2005 11:55 AM
alberto.garrido
Jul 27, 2004 09:33 AM
delguiner
Jul 8, 2004 08:32 AM
type r 01-1063
Jan 16, 2004 11:52 AM
