Pioneer Head Unit Need Help...
Old May 10, 2004 | 02:15 PM
White98's Avatar
Default Pioneer Head Unit Need Help...
I have a DEH-P6500. The problem I'm having is that sometimes I hear sound, sometimes I don't. It's applied to both CD and radio. I called Pioneer and was told that the power chip wasn't working correctly, and asked me to take it to a service center. I bought it thru ebay so it wouldn't be under warranty.
I'm wondering if anyone here had this problem and where you bought the power chip. I want to buy it and replace it myself.
Thanks a bunch in advance.
Old May 10, 2004 | 03:15 PM
From: eating the shit out of pizza in raleigh, NC, USA
Default Re: Pioneer Head Unit Need Help... (White98)
buy an external amp (4-channel) it will probably be cheaper than fixing it...or just get a new deck
Old May 11, 2004 | 12:32 PM
ShaunRR's Avatar
HT White Ops
Community Builder
There may also be a short in your speaker wires somewhere.
Old May 11, 2004 | 01:48 PM
White98's Avatar
Default Re: Pioneer Head Unit Need Help... (rochesterricer)
If it's a short from some wires, I would think it would shut the hu off. However, it just plays like normal. I checked the wires anyway, they are OK.
Yeah, I was thinking about getting a new unit too. I can get a new P660 for around 180. Pioneer would charge 58 + parts for the fix and I'll have to wait too. I hate waiting!
Thanks guys.
Old May 11, 2004 | 05:38 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Nope, it would play just like normal except there would be no sound. I've seen it a thousand times as an installer. It happens most often when a speaker blows. The speaker is starting to blow when you hear it crackle, and it ceases to function and creates a short when it is completely blown.
Old May 11, 2004 | 05:41 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Also, in addition to a blown speaker you must check ALL of the speaker wire. The short could be anywhere in the wire between the deck and the speakers.
Old May 12, 2004 | 07:40 AM
EFz6er's Avatar
What does it sound like when you say there is no sound? Is it absolutely quite or does it sound like the radio with really weak signal-real scratchy? If its scratchy then its possible you have positive and a negative touching
Old May 13, 2004 | 04:22 PM
White98's Avatar
That surprised me that it wouldn't shut off the hu. Maybe I should suggest this to Pioneer Most electronics stuff, computers, and other high tech equipments would shut off if a short is sensed.
Anyway, thanks for your inputs. Been so freaking busy. Maybe I can find some time next week to take it out and check the speakers and wiring. I installed it myself almost two years ago, and the speaker wires still running around in the trunk!!! You are probably right. I recently noticed that sometimes the sound would come back when I drove over a bumper. It could be that it opened the short. But sometimes, it just came back for no reason. Like last night, when I parked the car, it was playing just fine, but in the morning, it's completely blank. And I also experienced the opposite way too, no sound when parked and came back in the morning!!!
Again, thanks for your inputs. I'll keep all posted after I take a look so others can learn from my experience.
Oh, when I said, I hear nothing, I meant NOTHING, no sound, no noise at all.
Thanks.
Old May 13, 2004 | 05:31 PM
green91's Avatar
before you do anything, unplug the HU and using an ohm meter, measure the resistance to each speaker to make sure its not the wiring. you should typically receive between 4-8 ohms resistance if the speaker is good. you will receive infinite resistance if blown, and no resistance if its cut or came loose.
Old May 13, 2004 | 07:52 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: (green91)
Also, most digital multi meters have a setting that beeps when it is senses a ground or a short. If you have a DMM, use that feature on the + and - leads on all of the speaker wires and you will have your answer.
Old May 13, 2004 | 09:07 PM
White98's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by green91 &raquo;</TD></TR><TR><TD CLASS="quote">before you do anything, unplug the HU and using an ohm meter, measure the resistance to each speaker to make sure its not the wiring. you should typically receive between 4-8 ohms resistance if the speaker is good. you will receive infinite resistance if blown, and no resistance if its cut or came loose.</TD></TR></TABLE>
Thanks for offering help. That's what I have on mind, then the wires. BTW, if it's cut or loose, it would show OL (Open Loop) or infinite resistance. It'd only show zero resistance if there is a short.
FYI,
The beep function of some DVM's would beep if the resistance is anything less than 10 ohms. Thanks again.
Old May 13, 2004 | 09:40 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: (White98)
That function has ALWAYS worked for this problem on both my old Radio Shack DMM and my current Snap On one. I guess it depends on the quality of the unit.
Based_Pocket84
Jan 15, 2014 11:54 AM
alphalanos
Honda S2000
Mar 1, 2013 01:46 PM
chinoty
Audio / Security / Video
Nov 21, 2007 08:29 PM
Mr_EmO
May 17, 2005 06:02 PM
is3oo
Aug 31, 2003 08:13 PM
