d16a1 (p29) pistons into a d15b?
Old May 10, 2004 | 08:18 AM
trooper0641's Avatar
Default d16a1 (p29) pistons into a d15b?
Would these pistons clear? And what the hell is "claying"? How much compression do you think this is going for in a d15b?
Old May 10, 2004 | 08:22 AM
BauleyCivic's Avatar
Risky Business
Default Re: d16a1 (p29) pistons into a d15b? (trooper0641)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 &raquo;</TD></TR><TR><TD CLASS="quote">Would these pistons clear? And what the hell is "claying"? How much compression do you think this is going for in a d15b? </TD></TR></TABLE>
The pistons will barely clear.
Claying is putting this putty like substance on top of your pistons, then laying the head on, then cranking the motor over and checking clearances.
The compression will be approximately 14:1...not streetable. Emerika ran this setup and it pinged like a bitch even on high octane fuel. Why are you so bent on an engine build? Mill the head and then have it ported and throw a big-*** cam in there, or just turbo it.
JaeOne3345's Avatar
dont put 1.6 pistons in a 1.5 block unless you are using the rods from the vx or the jdm d15b vtec motor. piston pin/rod length measurements are different between the d15 and d16 motors.
if you put d16 pistons on non vtec rods, piston sits lower in the hole, making the job a waste of time.
edit: if you have the jdm d15b vtec they wont sit low, look at the above post.
Old May 10, 2004 | 08:24 AM
Default Re: d16a1 (JaeOne3345)
ahh sounds like a hassle...i just wanted to bump up my compression a bit when i change my head gasket. but i do have a jdm d15b.
Old May 10, 2004 | 08:25 AM
Default Re: d16a1 (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">
The compression will be approximately 14:1...not streetable. Emerika ran this setup and it pinged like a bitch even on high octane fuel. Why are you so bent on an engine build? Mill the head and then have it ported and throw a big-*** cam in there, or just turbo it.</TD></TR></TABLE>
holy **** 14:1...and i thought it was going to be in the low 12s high 11s.
Old May 10, 2004 | 08:26 AM
Risky Business
Default Re: d16a1 (trooper0641)
Don't **** with the bottom end unless you have to. It only leads to problems.
Old May 10, 2004 | 08:32 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">Don't **** with the bottom end unless you have to. It only leads to problems.</TD></TR></TABLE>
gotcha
Old May 10, 2004 | 08:33 AM
so...nobody knows a good piston setup into a d15b? i want a compression that will go with CA's 91 octane.
Old May 10, 2004 | 08:36 AM
d16a6 pistons (crx si)? high 10 low 11s compression ratio? Good?
Old May 10, 2004 | 08:56 AM
DerangedEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 &raquo;</TD></TR><TR><TD CLASS="quote">so...nobody knows a good piston setup into a d15b? i want a compression that will go with CA's 91 octane.</TD></TR></TABLE>
Use a Y8 headgasket and shave the head. Along with slightly bumped timing you may be able to still run 91 octane anything more and its ping city.
Old May 10, 2004 | 09:12 AM
Default Re: d16a1 (DerangedEG)
eh screw it...ill just stay with the way my d15b is.
Old May 10, 2004 | 09:16 AM
DerangedEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 &raquo;</TD></TR><TR><TD CLASS="quote">eh screw it...ill just stay with the way my d15b is.</TD></TR></TABLE>
that's a good motor. Use the edlebrock intake, 60-64 mm thorttle body, Si tranny, and a chipped ECU with a decent header and its money in a light car.
Old May 10, 2004 | 09:41 PM
Nobody has anything to say about using the crx si d16a6 pistons into a d15b?
iKhmaiFoSho
17
Sep 6, 2007 03:08 PM
Spectrum24x
Mar 9, 2006 07:14 AM
GusRock77
Honda S2000
16
Mar 1, 2005 12:24 PM
My_EP3
Apr 6, 2004 06:27 PM
blazin
Jul 11, 2003 06:11 AM
