1997 Civic HX?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skrewdriver88 »</TD></TR><TR><TD CLASS="quote">Somebody told me that when i go to buy engine parts for my 1997 Civic HX that i buy 1997 Civic EX parts. is that true?</TD></TR></TABLE>
Everything except engine components, yes. IE if you wanna buy a tite azz body kit, one designed for an EX will fit just fine.
whats are the main differences between the hx and ex? gear ratios, different air/fuel mix? I always thought they were the same except for the tranny and ecu program but not any real mechanical differences.
HX - 115 HP SOHC VTEC-E motor
EX - 125 HP SOHC VTEC Engine
They share absolutely no internal components. The heads, blocks, transmissions, manifolds, ECU's are all different.
As far as standard features are concerned...the EX has a sunroof, and bigger brakes than the HX. The HX however has those m4dd tyte wheels y0 (Which will not fit on an EX BTW because the brakes are too big).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skrewdriver88 »</TD></TR><TR><TD CLASS="quote">when i go to buy a short ram intake do i buy the kind for a EX? cause if not where do i buy one that is made for a HX?</TD></TR></TABLE>
Yes.
Yes.
You can buy pretty much anything that will fit an Ex for your Hx,,,,Cam Gear Pulleys Intake,,,,The Manifold is different and the header needs to be installed with separate Cat. I had a Kamikaze header on my 1998 honda civic Hx
rody084
11
May 9, 2005 05:00 PM
mushu315
14
Mar 30, 2005 10:16 PM
