help me pick an amp for my two 10's
current setup:
Pioneer deck
4g amp wiring kit
Alpine MRV T-707 (240watt RMS X 1 @ 4ohms, 120RMS X 2 @ 4ohms)
Subs:
2 Infinity 10” 1000-Watt Subwoofer
Sub Specs:
Subwoofer Size 10 Inch
Dual Voice Coil No
Impedance (Ohms) 4
Peak Power Handling (watts) 1000
Frequency Response (Hz) 25 - 250Hz
Sensitivity (dB) 90
Woofer Cone Material Polypropylene
Woofer Surround Material Rubber
Voice Coil Design Single Copper
Basket Material Stamped steel
xMax - Maximum Excursion (millimeters) 12.5
QTS .54
Fs - Free Air Resonance (Hz) 29
Recommended Amp Wattage Range 100 - 300 Watts
Mounting Depth (inches) 5-1/2
Vas (liters) Unavailable
Recommended Enclosure Type Sealed, Ported
Sealed Box Volume (cu. ft.) 0.75
Ported Box Volume (cu. ft.) 1.75
I'm just really scared of underpowering these subs. So, any recomendations would be nice. My Budget is $250.
TIA!
Pioneer deck
4g amp wiring kit
Subs:
Sub Specs:
Dual Voice Coil No
Impedance (Ohms) 4
Sensitivity (dB) 90
QTS .54
TIA!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jordan-boxer »</TD></TR><TR><TD CLASS="quote">300 rms is the recomended wattage for a 1000 watt sub? thought it would be 500
how did you determine 500? rms is the recommended power for the sub to function at its best. peak is the highest amount of power it can handle, not continuosly. i dont see how you determined 500 from that though...
</TD></TR></TABLE>how did you determine 500? rms is the recommended power for the sub to function at its best. peak is the highest amount of power it can handle, not continuosly. i dont see how you determined 500 from that though...
Usually you can take the peak power divide it by 1.414 and get the RMS power. But these manufacturers come up with some interesting ways to rate their products. Like wise you can take the RMS power and multiply it by 1.414 an get the peak power.
I would go with whatever the manufacturer rates the speaker at in RMS.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ndchancehonda »</TD></TR><TR><TD CLASS="quote">
from my experience
a sub can handle half of the continous power
my comp vrs were 400 rms 800 max, same with other subs ive owned
put it this way, if i bought that 1000watt infinity sub id feed it 500 rms thinking it could take it, didnt know it was 1.4 whatever times
i learn something new on ht every hour
</TD></TR></TABLE>from my experience
a sub can handle half of the continous powermy comp vrs were 400 rms 800 max, same with other subs ive owned
