need help!!!! vtec's gone!!!!
Old May 10, 2004 | 02:52 AM
BumpinVTEC's Avatar
Default need help!!!! vtec's gone!!!!
alright i posted a thread a while ago on how my gsr smokes when vtec hit, so anyways i just took a long drive yesterday to do a delivery for work using my own car, a jdm b18c hatch, bolt ons and ctr cams untuned running a stock p72 ecu. I drove a about 200 miles there and back most of the time i was cruising on my first vtec doing about 90/95 most of the way, all was fine until my check engine light came on, and vtec wasnt hitting, i checked my oil levels to see if they were cool, i was short so i added some more oil and a vtec started to work again, this was yesterday, now when i hit vtec he goes off sometimes and doesnt do **** at all other times, also the car feels like its struggling really bad around between 7 and 8 thousand rpms, when vtec does hit it's interrupted meaning vtec will shut on and off between the time it takes to engage to redline, everytime vtec cuts off, i see a puff of whitish bluish smoke shoot out, you can even feel the car shoot it out, i know blue means oil, so does this mean that my rings have diffenently gone bad???
Old May 10, 2004 | 09:21 AM
BlackThorN's Avatar
Default Re: need help!!!! vtec's gone!!!! (BumpinVTEC)
I"d check your oil again today and see if your car is eating the hell out of it
also you may want to do a compression test
Old May 10, 2004 | 01:19 PM
BumpinVTEC's Avatar
Default Re: need help!!!! vtec's gone!!!! (BlackThorN)
thanks, checked it today, lost some oil but not much
Old May 10, 2004 | 01:22 PM
Miracle_X_Bar's Avatar
Could be your oil pump!! Could be your v-tec solenoid, check everything.
Old May 10, 2004 | 02:18 PM
Toda Built's Avatar
Default Re: need help!!!! vtec's gone!!!! (Miracle_X_Bar)
also check your knock sensor...vtec wont crossover unless your knock sensor is operational
Old May 10, 2004 | 04:57 PM
hotintegranights's Avatar
Default Re: need help!!!! vtec's gone!!!! (Toda Built)
i think your computer is very smart by not letting you engaged vtec,belive it or not this safes a lot of peeps motors out there. well there is def something wrong with the motor, do a compression test, hear for any knocks, and if your adding more than 2 quarts a week def time for a rebuild.
Old May 10, 2004 | 06:35 PM
RZProStreet's Avatar
Default Re: need help!!!! vtec's gone!!!! (hotintegranights)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Miracle_X_Bar &raquo;</TD></TR><TR><TD CLASS="quote">Could be your oil pump!! </TD></TR></TABLE>
Same thing happened to me. Replaced the pump with a new one and everything is fine now.
Old May 10, 2004 | 08:11 PM
NiceDc2r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackThorN &raquo;</TD></TR><TR><TD CLASS="quote">I"d check your oil again today and see if your car is eating the hell out of it
offspringpunk14
12
Sep 23, 2009 07:16 AM
bhigh
Jun 22, 2009 07:44 PM
honda_student
Dec 4, 2007 12:18 PM
dimwitrj
May 16, 2007 11:02 AM
92GSR
Apr 28, 2002 10:06 PM
