ctr intake/gsr exhuast cam combo...does it work?
i heard that using a ctr intake cam and a gsr exhuast cam will make loads of power in a b series motor. im planing on using this setup after i finish building my ls/vtec shortblock.
does anyone have any information on this type of camshaft combo?
thanks
thanks
you'll make less power if you use the both CTR/ITR cams.
BTW, ITR exhaust cam= CTR exhaust cam
00-01 ITR intake cam = CTR intake cam
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DefiantGSR »</TD></TR><TR><TD CLASS="quote">you'll make less power if you use the both CTR/ITR cams.
why would you make less power w/ ctr/itr cams set up? Isnt that just basically running 00-01 ITR cams?
I'm running the ctr intake cam and the stock gsr exhaust cam on my gsr....noticed a slight increase in power in the higher rpm's, but that was about it. I just recently bought an itr exhaust cam, and want to throw that in, but I want to wait and get valve springs and retainers for security purposes. Doing the ctr intake cam isnt a bad mod to do.....go for it
i've had both combos and my impressions are that the itr intake/gsr ex. combo definitely works and is a great upgrade over the gsr intake cam....made alot of midrange also
when i installed the itr exhaust cam it definitely shifted my power curve upwards.....topend gains were significant but midrange felt the same
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ »</TD></TR><TR><TD CLASS="quote">
why? GSr exhaust cam has less lift and duration. Its as simple as that.
</TD></TR></TABLE>why? GSr exhaust cam has less lift and duration. Its as simple as that.
I've seen dyno graphs of a B16 making 190+whp with a ITR int cam / GSR exhaust cam. This made signifiantly more power than Skunk Stg 2 on this motor.
Motor was BubbaBuilt and Tuned by TEAMGENDAI.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket »</TD></TR><TR><TD CLASS="quote">I've seen dyno graphs of a B16 making 190+whp with a ITR int cam / GSR exhaust cam. This made signifiantly more power than Skunk Stg 2 on this motor.
Motor was BubbaBuilt and Tuned by TEAMGENDAI.</TD></TR></TABLE>
are you stating the potential of the ITR/GSR combo? Or are you stating that if he went with both ITR cams he would not have made as much power.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DefiantGSR »</TD></TR><TR><TD CLASS="quote">well, it was a b16
from what i've seen, B16s seem to not like anything above a CTR/ITR/stage 1 cam.</TD></TR></TABLE>
Werd.
Werd.
I've seen a 96 GSR dyno chart and he put down 170 whp and 130 torque after being tuned. His list of mods: Honda Integra R Intake Cam, Trust BL Exhaust, RS*R Ceramic Header, AEM Intake and AEM Cam Gears. Pretty impressive IMO.
why do people actually buy "stock parts" from other motors. **** that ****. upgrade the head with some isky valve springs and retainers and get a stage2 or stage 3 jun cams....
save your money for the better things...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ceLtic »</TD></TR><TR><TD CLASS="quote">why do people actually buy "stock parts" from other motors. **** that ****. </TD></TR></TABLE>
its called honda reliability....from my experience and the **** ive seen.... they seem to last longer then aftermarket stuff...
besides one itr cam is about 250 bucks, go and buy a pair of toda spec bs and itll run you almost 1g. and now ur sacrificing a good idle and gas mileage on a street driven motor.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wickedsi408 »</TD></TR><TR><TD CLASS="quote">wicked-industries.com- try goin with some stage 2's </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9d DA6 TEG »</TD></TR><TR><TD CLASS="quote">its called honda reliability....from my experience and the **** ive seen.... they seem to last longer then aftermarket stuff...</TD></TR></TABLE>
I put a ctr intake camshaft, and an itr exhaust camshaft on both my b series and h series vtec all motors. The ctr/itr combo produced a 26hp increase... This was in my 1990 Jdm civic, and the same setup prduced a good 24 more horse power in my H22A prelude. So go for it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FerioVtec94 »</TD></TR><TR><TD CLASS="quote">i've had both combos and my impressions are that the itr intake/gsr ex. combo definitely works and is a great upgrade over the gsr intake cam....made alot of midrange also
when i installed the itr exhaust cam it definitely shifted my power curve upwards.....topend gains were significant but midrange felt the same</TD></TR></TABLE>
isn't the itr and gsr exhaust cam pretty much the same?
would it be even worth putting the itr exhaust cam?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jacob. »</TD></TR><TR><TD CLASS="quote">I put a ctr intake camshaft, and an itr exhaust camshaft on both my b series and h series vtec all motors. The ctr/itr combo produced a 26hp increase... This was in my 1990 Jdm civic, and the same setup prduced a good 24 more horse power in my H22A prelude. So go for it
so your saying...you put B series cams in an h22?
</TD></TR></TABLE>so your saying...you put B series cams in an h22?
