I need to get out some rivets!!
Old May 9, 2004 | 06:26 PM
DMF's Avatar
DMF
Default I need to get out some rivets!!
I am helping someone with suspension in a Ford truck right now and we had to cut some heads off of rivets to get a hanger off the frame. We now need to get the rest of the rivets out of the frame and hitting them doesn't seem to work. Any ideas from anyone. Do you think heating them up with a torch and then hammering on them would work? I know it's not a Honda, but though someone might have an idea.
Old May 9, 2004 | 06:44 PM
Lonny's Avatar
Default Re: I need to get out some rivets!! (DMF)
Usa a small drill bit and drill them. The head will break off and the rivet will come right out. Done it this way many times with no problems.
Old May 10, 2004 | 07:53 AM
Wes V's Avatar
Default Re: I need to get out some rivets!! (Lonny)
DO NOT USE HEAT!
You could use strength in the frame rail steel. Use a drill as recommended in the prior post.
Wes V
Old May 10, 2004 | 08:27 AM
APEX CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lonny &raquo;</TD></TR><TR><TD CLASS="quote">Usa a small drill bit and drill them. The head will break off and the rivet will come right out. Done it this way many times with no problems.</TD></TR></TABLE>
or a small grinding tool will work in a pinch but the drill bit will be easier
ExVtec
Welding / Fabrication
15
Oct 8, 2008 06:14 AM
b20vtech
Mar 30, 2008 06:49 AM
99teggsr
Apr 19, 2005 10:55 AM
Want2race
Feb 16, 2005 04:12 AM
ExiledinIN
12
Nov 30, 2003 05:36 PM
