JDM ITR slugs in GSR Motor- A few questions!
Ok well my setup is planned to be this-
B18c1-block and head(stock cams for some while)
ITR slugs
Spoon Headgasket
-What would be overall compression?
-We can use 93 octane here in florida, my question is will i have detonation issues becuase my compression is too high? Will i have to go w/another head gasket?
-I also plan on getting .25 oversize. I guess i will have to bore and hone some .25 more. Will stock sleeves handle this? What is max that can be bored/honed?
ITR slugs
Spoon Headgasket
ive got jdm itr pistons in my gsr block w/ gsr head and im in SC. Its my 1st n/a build(always been a FI guy) and w/ 93 its just fine. W/o the spoon headgasket i believe the CR is around 11.4:1....everything should be just fine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 10seceg »</TD></TR><TR><TD CLASS="quote">ive got jdm itr pistons in my gsr block w/ gsr head and im in SC. Its my 1st n/a build(always been a FI guy) and w/ 93 its just fine. W/o the spoon headgasket i believe the CR is around 11.4:1....everything should be just fine
11.4:1 W/O the spoon headgasket?? What about with it???
The spoon headgasket will bump compression, if i'm not mistaken.
</TD></TR></TABLE>11.4:1 W/O the spoon headgasket?? What about with it???
Should be about 11.7ish range with the spoon headgasket. I have jdm ITR's in a gsr with the stock headgasket tuned on 92 octane and its runs great. Compression test results are 270 psi across all four cylinders for my motor.
well if your going with 81.25 pistons then your comp will be 11:7 .
the max you can safely bore out your stock sleeves is to 81.50,
some people have gone with 82mm which is not and overkill
and AN-R sells for a good price.
and some even up to 83mm,but 83mm would require some really good
ems tunning and good fuel.
yoorang
Jul 22, 2006 10:35 AM
Tyson Ballou
Nov 8, 2001 05:50 AM
