Gear Shift lock
Old May 9, 2004 | 12:29 PM
crystalclear444's Avatar
Default Gear Shift lock
When I try to put my car in gear, the shift won't unlock unless I use a second key to depress the lock in the gear shift. Any suggestions?
Old May 9, 2004 | 02:45 PM
bill-71SS's Avatar
Default Re: Gear Shift lock (crystalclear444)
do your brake lites work? if not ,replace the switch
Old May 9, 2004 | 03:03 PM
Default Re: Gear Shift lock (bill-71SS)
My brake lights don't work either. Do you think that is related to the fact that the gear lock shift isn't unlocking either? Thanks!
Old May 9, 2004 | 03:42 PM
bill-71SS's Avatar
you need a brake lite switch,it is on the brake pedal,not too hard to change
Old May 9, 2004 | 07:45 PM
Riceburner247's Avatar
Yup, replace that switch. You'll fix both those problems.
Old May 10, 2004 | 07:47 AM
Thanks for your help
Old May 10, 2004 | 04:44 PM
I've checked the brake pedal and can't seem to locate where the brake switch might be. It is actually located on the pedal itself? Any visual advice would be great, thanks.
kizzle82
Dec 8, 2017 03:06 AM
1sikhatch
Dec 3, 2010 07:17 AM
sageuvagony
Mar 25, 2010 05:05 PM
DRKSol
Acura TL, RL & ZDX
Dec 18, 2009 04:20 PM
idewson
Nov 22, 2007 11:37 AM
