Torque spec for spark plugs?
Old May 9, 2004 | 11:24 AM
ITRFetish2000
Guest
Posts: n/a
Default Spark plug question for ITR owners...
I know most of you guys put your plugs in by hand and tighten them by hand, but I was wondering what the proper torque specs are for installing spark plugs? I need ft-lbs please....thanks guys! I've heard 13lbs and 20lbs. Which is it. Will 20lbs damage the threads in the cylinder head?
Old May 9, 2004 | 11:47 AM
uNF$@#!'s Avatar
Default Re: Spark plug question for ITR owners... (ITRRTI)
if you hand tight it its going to be around 13 ft lbs anyhow.
if you went ahead with 20 ft lbs, no point in worrying about it now...just correct it.
the damage, if any, has already been done, and if no damage, consider yourself lucky and buy a helms.
Old May 9, 2004 | 04:59 PM
stumpyf4's Avatar
Default Re: Spark plug question for ITR owners... (Soup ****)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soup **** &raquo;</TD></TR><TR><TD CLASS="quote">if you hand tight it its going to be around 13 ft lbs anyhow.</TD></TR></TABLE>
13lb/ft is what is specified.
Old May 9, 2004 | 05:01 PM
.RJ's Avatar
.RJ
Default Re: Spark plug question for ITR owners... (jdm wannabe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm wannabe &raquo;</TD></TR><TR><TD CLASS="quote">NGK specifies to tighten by hand then turn 3/4 </TD></TR></TABLE>
huh?
Old May 9, 2004 | 05:15 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm wannabe &raquo;</TD></TR><TR><TD CLASS="quote">tighten the spark plug until it seats, then turn another 3/4 of a turn</TD></TR></TABLE>
Incorrect....
Old May 9, 2004 | 05:40 PM
vtec.dc2's Avatar
Default Re: Spark plug question for ITR owners... (.RJ)
3/4 the of a turn is about right i think, according to my torque wrench it takes about 2/3rd of a turn after spark plug seats.
Old May 9, 2004 | 05:41 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm wannabe &raquo;</TD></TR><TR><TD CLASS="quote">maybe arno was right and this forum really is that dumb.... </TD></TR></TABLE>
There are torque specs for a reason, especially with aluminum heads.
Old May 9, 2004 | 05:44 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm wannabe &raquo;</TD></TR><TR><TD CLASS="quote">man, explaining things to you is really of no use is it.....&lt;shrug&gt;</TD></TR></TABLE>
Enlighten me then, simce you think I'm an idiot.
Old May 9, 2004 | 05:47 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm wannabe &raquo;</TD></TR><TR><TD CLASS="quote">ive wasted enough of my time on you already.... </TD></TR></TABLE>
While installing plugs to "hand tight + 3/4 turn" may work for you but its just not the correct way to do it. NGK doesnt say use anti-seize on the threads, so do you leave that out also?
Old May 9, 2004 | 05:57 PM
.RJ's Avatar
.RJ
Just because I think you are talking out of your ***....
Old May 9, 2004 | 06:24 PM
FyrFytr's Avatar
St00pid is as st00pid does.
Let her learn on her 0wn RJ.
Old May 9, 2004 | 06:37 PM
DragII's Avatar
25 Year Member
Default Re: Spark plug question for ITR owners... (FyrFytr)
I've always torqued mine down to 12-14lbs
Old May 9, 2004 | 06:47 PM
BauleyCivic's Avatar
Risky Business
Nice one .RJ
JDMfrontedLS
Mar 30, 2006 09:11 PM
Black R
Oct 13, 2005 11:48 AM
spicoli
Sep 17, 2004 09:52 AM
JL 74
Jun 15, 2004 09:36 AM
paulyman
May 20, 2002 07:11 PM
