NEED HOW-TO: Getting at 6x9's in 2000 Civic!!
Old May 9, 2004 | 10:43 AM
JoshuaVTEC's Avatar
Default NEED HOW-TO: Getting at 6x9's in 2000 Civic!!
I need to get at the 6x9's in my 2000 Civic Si in order to change them out with the Alpine ones I just got.
I'm told I have to take out the back seats, side panels, and upper deck to do it.
Anyone have a write-up or how-to? I heard it was a pain...
Old May 9, 2004 | 04:02 PM
ScubaStevo80's Avatar
Default Re: NEED HOW-TO: Getting at 6x9's in 2000 Civic!! (JoshuaVTEC)
Use the helms... you do have ot take out the seats, thats why I never put them in my car. Too much work and I didnt' have the time.
Old May 9, 2004 | 05:40 PM
From: eating the shit out of pizza in raleigh, NC, USA
Default Re: NEED HOW-TO: Getting at 6x9's in 2000 Civic!! (VolpeOwnsU)
go to best buy, pay 32.99 and get it over with...
Old May 9, 2004 | 06:40 PM
B18C_EJ8's Avatar
Definitely a pain in the ***.. But a necessary evil, I guess... You've been told correctly... Seats, side panels come out, then rear deck pops out... Set aside a good couple of hours if you've never done something like that before....
Old May 9, 2004 | 07:31 PM
stillencivic's Avatar
Default Re: (B18C_EJ8)
i did a right up about this a little while ago... let me see if i can find the link...
Old May 10, 2004 | 11:12 AM
JoshuaVTEC's Avatar
Default Re: (stillencivic)
Find it?
Here's the pics...
Old May 10, 2004 | 01:02 PM
B18C_EJ8's Avatar
Just in case you didn't know, you're not going to use those grilles, unless you're planning on cutting your rear deck...
Old May 10, 2004 | 01:21 PM
JoshuaVTEC's Avatar
No cutting.
Old May 12, 2004 | 08:06 AM
Cam79's Avatar
Default Re: (JoshuaVTEC)
Nice , what did those run ya?
Im planning on getting a new deck and speakers here soon.
Old May 12, 2004 | 10:14 AM
TurboBumblBee's Avatar
Default Re: (C00SI)
plan on a couple hours if youve never done it before.. ive done it before and its a pain in the ***.. nice speakers.. hope your running a 4 channel to those, they can handle the power and sound 1000x better when powered good..
Old May 12, 2004 | 11:40 AM
jordan-boxer's Avatar
Default Re: (Boostfedb18c1)
those alpine are DVC???? and 50rms watts????,yjuffvy
Old May 12, 2004 | 12:54 PM
JoshuaVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">hope your running a 4 channel to those, they can handle the power and sound 1000x better when powered good.. </TD></TR></TABLE>
Alpine MRV-F340 will run those
Old May 12, 2004 | 12:56 PM
Default Re: (jordan-boxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jordan-boxer &raquo;</TD></TR><TR><TD CLASS="quote">those alpine are DVC???? and 50rms watts????,yjuffvy </TD></TR></TABLE>
ive heard those same speakers powered by a big 4 channel amp in my friends 96 civic and they sounded great.. definatly a great speaker for as cheap as they are before going into the higher price ranges..
Old May 12, 2004 | 01:20 PM
JoshuaVTEC's Avatar
The Alpine 6.5" component set arrives tomorrow...
Old May 12, 2004 | 08:59 PM
sceg's Avatar
im 99.99999% sure they are not dual voice coil, the 2 inputs are seperated, one for the tweeter and one for the 6x9 cone. you can run them straight from seperate outputs of your amp (using the amp/radio crossovers, depending on what you have) or the crossover that comes with the speaker
Old May 14, 2004 | 10:27 AM
niccuhles's Avatar
those arnt DVC, the have to seperate hook-ups for the crossover that comes with them, just like what SCEG said
Old May 14, 2004 | 12:16 PM
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoshuaVTEC &raquo;</TD></TR><TR><TD CLASS="quote">
Alpine MRV-F340 will run those </TD></TR></TABLE>
hmm...i've got the same amp and the same speakers but after bi-amping the front speakers and running front stage only, i took the 6x9's out they've been sitting in my closet for about a year now.
rear fill
Old May 15, 2004 | 09:30 AM
Mr. Vapor's Avatar
Default Re: (EBP_SI)
anyone find that link yet?
I also need to know how to remove the 6x9s in my '00 civic to put in my eclipse speakers.
Old May 15, 2004 | 10:43 AM
sopiwnykg's Avatar
Default Re: (Mr. Vapor)
1. Fold down both sections of rear seat. UN-bolt all 6 gold colored bolts (10 mm) that secure seat to brackets.
2. Remove side brackets (2-12 mm bolts)
3. remove 1-10mm bolt that secures seat bottom. Unclip front clips and remove.
4. Extract 1-philips screw from each lower portion of side panel.
5. Using panel popper to aide in removal, take out both side panels.
6. Now carefully remove rear deck cover without breaking white pressure clips.
7. There u have it in 20 min or less.
Found this in an archived article
Old May 23, 2004 | 02:59 PM
Mr. Vapor's Avatar
Default Re: (sopiwnykg)
sounds simple............but whats a "panel popper?" I dont have one, what can be used in its place to assist my install.....?
Old May 23, 2004 | 03:44 PM
JoshuaVTEC's Avatar
You won't need a panel popper, I had one handy and didn't even need it.
The process is real simple if you follow the directions posted above.
Old Jun 8, 2004 | 10:22 PM
crazy eyez killa
Guest
Posts: n/a
Default Re: (niccuhles)
which wire is positive, which is negative??
Old Jun 9, 2004 | 04:40 AM
sceg's Avatar
Default Re: (YOUR MAMA)
in older hondas, the gray and brown wires were neg., im not sure what year yours is though. but if the pairs are blue/gray and red/ brown then there is your answer
Old Jun 9, 2004 | 09:24 AM
crazy eyez killa
Guest
Posts: n/a
Default Re: (sceg)
Mines a 99. I figured out the yellow stripe is +, white stripe is -,
I also removed my rear deck without removing the seats or side panels. Just unclip the side panels at the top and pull them back a little bit, the rear deck will pop right out.
Old Jun 15, 2004 | 10:25 AM
Mr. Vapor's Avatar
Hey guys........I got to step #4 and got stuck. where is/are these screws at? lost!
