6th gen accord, auto to manual conversion
Old May 9, 2004 | 10:07 AM
jlv55's Avatar
Default 6th gen accord, auto to manual conversion
ok, this isnt a thread about whether to do it or not, this is a thread all about douing it. i dont want anyone saying its not worth it, because i am doing it regardless of the cost or amount of time it takes.
first question, since 6th generation accords in 5spd are more rare, would it be possible for me to use the pedal assemble from a 5th generation accord?
Old May 9, 2004 | 12:35 PM
H2290's Avatar
Default Re: 6th gen accord, auto to manual conversion (klutch44)
You can use any pieces you want as long as things like the linkage and all are long enough. Check the distance you are gonna need between everything and find the longest linkages and such you can. 5th gen would probably be a good idea. Actually shouldn't be too difficult though I'm sure it would be easier if you just swapped to say a H22 tranny or something and it came with all the necessary hardware. Then you could just start hacking away. The only thing is you would probably have to get the ECU from a manual Accord of your year. don't really know what else could help you.
Get the parts you need and start cutting.
Old May 9, 2004 | 12:38 PM
jlv55's Avatar
Default Re: 6th gen accord, auto to manual conversion (H2290)
well i am actually going to use an manual ECU from a prelude, since i am using the prelude transmission. right now i only have an auto ecu. it'll work, but i'd rather have the one for manual.
im hoping that i can use pedals from a 5th gen, and maybe even the clutch cylinder and hydrolic lines, but i will most likely need the linkage from a 6th gen.
Old May 9, 2004 | 12:40 PM
fw190bvi's Avatar
EDIT: so ur using an H22 or f22 tranny???....why not just use the prelude pedals pedals (their probably the same)??
Old May 9, 2004 | 02:12 PM
jlv55's Avatar
Default Re: 6th gen accord, auto to manual conversion (fw190bvi)
i am using an h23 engine, and h23 tranny. the engine is from an automatic car, and i do not have 5spd pedals.
Old May 9, 2004 | 02:23 PM
FatJoe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klutch44 &raquo;</TD></TR><TR><TD CLASS="quote">well i am actually going to use an manual ECU from a prelude, since i am using the prelude transmission. right now i only have an auto ecu. it'll work, but i'd rather have the one for manual.
im hoping that i can use pedals from a 5th gen, and maybe even the clutch cylinder and hydrolic lines, but i will most likely need the linkage from a 6th gen.</TD></TR></TABLE>
when you swap a manual tranny into your car the auto ecu wont work, you have to use a manual ecu. hence why there are auto and manual ecus and not just a universal ecu.
Old May 10, 2004 | 07:35 AM
jlv55's Avatar
Default Re: 6th gen accord, auto to manual conversion (FatJoe)
well, technically you can use the automatic ECU, but you will usually get a CEL. i've seen it done before, but i'd rather not do it if i dont have to.
Old May 10, 2004 | 08:13 AM
H2290's Avatar
You should go fishing in a junkyard for a manual ECU from an H23 or at least an H22.
Old May 14, 2004 | 01:48 PM
jlv55's Avatar
i just picked up a manual ECU for $20.
Old May 18, 2004 | 03:53 PM
jlv55's Avatar
help me, i need pedals and linkage.
Old Nov 21, 2004 | 11:57 AM
Em0ne's Avatar
we got some pedals for sale if you haven't found em...
Mr.Pink
Sep 30, 2004 11:26 PM
sloaccord96
Nov 26, 2001 08:08 PM
sloaccord96
Nov 25, 2001 09:49 PM
