NEED HELP!!!!!!!!!!! ON MY LS VTEC FULLY BUILT TURBO BEAST!!!!!!!!!!!!!!!!!!!
I have a fully built LS vtec engine ready for turbo going into my 89 crx hf. I will be converting to obd1 for a hondata ecu. I have the following mods below done to it.
Bottom: b18a1 LS 90-93, Darton open deck sleeves, bored 2.0L, crower pro billet rods, JE custom 9.2-1 ls vtec pistons. type r oil pump, gsr water pump,
Head: b16a SS valves, Skunk2 valve springs and retainers, oem keepers, Stage 2 pNp, JG manifold, AEM fuel rail and pressure reg.
Transmission: 91 cable LS with PG LSD, ACT 12 lb flywheel, ACT street strip 6 puck clutch
Not sure what turbo to use? SC series? not sure what cams to use? not sure what hondata ecu system to get and options? not sure what size of injectors? not sure of what kinda power I will be making? max boost? 20 psi? not sure of what size of IC piping 2.5? not sure what size of TB? should I use an oil cooler? NEED HELP!!!!!!
Redwidow
Oct 21, 2007 04:59 PM
ExplicitSpeed
Nov 23, 2004 05:39 AM
ExplicitSpeed
May 9, 2004 04:46 AM
