Coolant leaking onto passenger floor
Old May 9, 2004 | 08:42 AM
eternity0114's Avatar
Default wet spot in passenger floor
Does anyone have a wet spot around their passenger side floor? I seem to be having some coolant leak and it is seeping through my car and soaking up in my carpet. Can anyone tell me where the leak might be coming from? Im scared taht it might be leaking from the block. P.S. its not the radiator cus i changed it just recently
Thanks
Old May 9, 2004 | 08:48 AM
non-VTEC's Avatar
Default Re: wet spot in passenger floor (eternity0114)
if you have coolant leaking on the inside of the passenger compartment you probably have a leaking heater core.......they are a real pain in the *** to replace also.
first check that the hoses connecting through the firewall are connected and sealing properly. if they are then the core is leaking which sucks big time......
Old May 9, 2004 | 09:15 AM
Bbasso's Avatar
Have you been using the A/C? if so it might be the condensation (sp?)
Old May 9, 2004 | 11:06 AM
HS2G's Avatar
Default Re: wet spot in passenger floor (Bbasso)
Yes the Ac wire that leads out of the car might just slip into the car. Just pull out the carpet and reconnect it.
Old May 9, 2004 | 12:35 PM
b19coupe's Avatar
Find out if it is coolant or water. Coolant = leaking heater core. Water = plugged or disconnected evaporator drain hose. Pray for water
Old May 9, 2004 | 02:06 PM
Im sorry, i didn't clearify it, i meant coolant as in radiator fluid. I tried to soak it up with a towel, and it was green.
Old May 9, 2004 | 03:07 PM
DragII's Avatar
25 Year Member
Default Re: (eternity0114)
leaky heatercore....expensive to have someone else fix it, time consuming pita to do yourself....just did one on a wrx a few weeks ago.
Old May 9, 2004 | 07:53 PM
magic hat #9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eternity0114 &raquo;</TD></TR><TR><TD CLASS="quote">Im sorry, i didn't clearify it, i meant coolant as in radiator fluid. I tried to soak it up with a towel, and it was green. </TD></TR></TABLE>
holy hell that must smell like **** in your car
Old May 10, 2004 | 06:00 AM
CW-ITR's Avatar
If you can stand the winter cold, eliminate the use of the heater core by just joint the input hose (to the heater core) and the return hose (from the heater core) together-leaking problem is solved. Both hoses are accessible from the engine bay. I'm hoping not to get any negative comment for my suggestion.
Chris
Old May 10, 2004 | 10:20 AM
thank you Chris, do you have any pix that could possibly help me out for the fix?
Old May 10, 2004 | 02:20 PM
bdb's Avatar
bdb
Check.. https://honda-tech.com/zerothread?id=838162
Old May 10, 2004 | 02:27 PM
1GreyTeg's Avatar
Default Re: (magic hat #9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by magic hat #9 &raquo;</TD></TR><TR><TD CLASS="quote">
holy hell that must smell like **** in your car </TD></TR></TABLE>
Shmells like French Toast.
Go figure, me with the food analogy.
LGxGirL
Nov 26, 2012 10:58 AM
TylerLorenz
May 31, 2009 07:30 AM
zumiez007
Aug 1, 2005 11:53 AM
deechiguy
Mar 4, 2005 08:53 AM
dunkd
Nov 13, 2003 07:28 AM
